New 2009 2010 BMW Z4 - ZPOST
      06-06-2014, 09:12 AM   #1
DEA333
Drives: 2016 i3 REX
Loss of power, shudder, and hesitation
Anyone else have problems with the car shuddering from a stop or the car losing power while accelerating or hesitating? The DSC sensor and HPFP has already been replaced and the clutch adaptation has been reset yet the problems persist.
I also have been having various electric issue with the AC not working, windows that will not stay up, and various iDrive problems.
      06-06-2014, 12:30 PM   #2
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
check out in the injectors ?
      06-06-2014, 01:03 PM   #3
Drew@Sonic MS
Drew@Sonic MS's Avatar
334
Drives: F80 M3
Most likely injectors, had similar issues with worn out injectors.
      06-06-2014, 01:51 PM   #4
Mak135i
Drives: 911 GTS, X3M
Exact same problem turned out to be injectors on my N54 135i. There was a SB on that issue from several years ago
2019 911 GTS
2017 M4 CV
2017 Mini JCW
      06-06-2014, 02:55 PM   #5
COOLZ4
Secret Agent
Drives: 2011 sdrive35is
I keep hearing about problems with the injectors. I only use premium unleaded in my car which is what's recommended by the manufacturer. So far I have had no issues.
There is also up to 15% ethanol added to our fuels here in the USA which can't be good on the injectors.
Is there any particular fuel treatment recommended for use in our cars to help prevent this problem?
      06-06-2014, 03:47 PM   #6
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
I have only ever had "top tier" 91 and 100 octane fuel in my car, and make sure the oil is up to operating temperature (and then some) to minimize carbon deposits and still had injector failure. Not sure there is anything we can do short of replacing them when they fail.
      06-06-2014, 05:15 PM   #7
Drew@Sonic MS
334
Drives: F80 M3
There's someone servicing injectors on e90post... Much rather just get a brand new set for piece of mind. Not sure what model injectors you have but get the updated ones if you end up getting new ones.
      06-06-2014, 06:27 PM   #8
jparnes1
jparnes1's Avatar
248
Drives: 2016 340i, 2012 Z4 35i
FWIW I throw in some fuel treatment every 5000 miles for good measure.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA.
      06-09-2014, 10:58 AM   #9
DEA333
Drives: 2016 i3 REX
The injectors have pretty much been ruled out. The problems started shortly after delivery has been serviced 8 or 9 times already and I don't even have 10k miles on her. The service department seems to agree that it's an electronics issue but since it's intermittent and hasn't been throwing any codes lately there is not they can do.
Just an update, after I submitted my original post all four windows kept opening and wouldn't stay closed (and yes it was raining). It took a restart to get this issue solved for now.
      06-09-2014, 12:43 PM   #10
2011CrazE89
Moved on
2011CrazE89's Avatar
Drives: 2011 Z430i & 2015 MB C300
Mine feels like it's going to stall right before coming to a complete stop. Only when the A/C is on. The entire car shakes when coming up to stop signs and red lights. As soon as I take my foot off the brake it's fine. Dealership cannot duplicate the issue??
      07-02-2014, 08:09 PM   #11
shlai
Hong Kong
Drives: 2009 Z4 E89 3.5i DCT
I have experienced a few stall within 2 months. 3 times whe I backed into parking and 1 time after going over a speed bump at parking lot gates ~ all at nearly normal idle RPM. All had no error code after checking with bluebooth ; in fact, no even audible warning or warning sign on the dashboard
      07-02-2014, 11:24 PM   #12
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
There's something YOU can do, and that is lawyer up and check on your state's lemon laws. (or at least contact BMWNA and politely mention your intent to lawyer up as well as the issues you have been facing with your 1 year old car)
      07-03-2014, 05:51 AM   #13
cuddapah
Drives: 2011 BMW Z4 sDrive 35i
Can you please give more details on fuel treatment.
      07-03-2014, 07:37 AM   #14
jparnes1
jparnes1's Avatar
248
Buy some Techron (20 oz size) and pour it in the tank every 5k. It helps to clean the injectors and minimize carbon buildup.
      07-03-2014, 07:48 AM   #15
jparnes1
jparnes1's Avatar
248
Nick is right. So much trouble right out of the box smells like a lemon. Check out what the FLA lemon laws says. NY lemon law says if your car is less than 18 months old and has been serviced 4 times or 30 days in the shop for the same problem, you qualify under the law.
However BMW will not let you lemon the car. They will offer a buy back and put you in a new car. Talk to your sales manager or if he's not receptive call BMWNA.
      07-03-2014, 10:21 AM   #16
airmarc
Drives: '10 BMW Z4,'14 BMW X3, '17 X1
Exact same here. Doesnt happen often though. And only when AC is on
      07-03-2014, 12:49 PM   #17
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
Guys, at the risk of stating the obvious, it is NOT normal that your car feels like it is going to stall with the AC on. Even if the ambient temps are 100F and the AC is working at full capacity that shouldn't happen.
If possible, take a vid, take the techs for a test drive, etc
      07-03-2014, 02:10 PM   #18
2011CrazE89
Moved on
It does it at least twice a week. I did notice that the RPM's drop to 0 and then immediately jump back up as soon as I release the brake. I've been to the dealer three times and they could never duplicate it. Very Frustrating.
      07-03-2014, 02:41 PM   #19
Bob20124
Retired and Enjoying it
Bob20124's Avatar
Drives: 2011 Z4 35i Alpine White 6MT
Could it possibly be battery or cable issue? Might be worthwhile to monitor voltage from aux power point and see if any correlation. low rpm + load (ac / brakes). Voltage drop?
2011 35i BMS High & Low side OCC, Custom tune, CDV delete, Eldor coils, ER Charge Pipe w/Tial BOV, ER Comp. FMIC, K&N drop in,40W LED Halo, LCI side markers, M-Factory LSD, NGK plugs, Racing Dynamics strut brace, Stubby, Windrestrictor
      07-03-2014, 02:55 PM   #20
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
Keep at it, and make sure it is documented they tried to find but couldn't so that when they do find it, you have a paper trail of the first time you reported the problem and an estimate of the time you have used up in the shop.
Also take a vid and document all the things you can when it happens (i.e. how long you've been driving, ambient temp, status of the AC, etc etc)
I know the feeling well since I am working through my own intermittent problem with the headlight aiming at the ground from time to time
      07-04-2014, 10:46 AM   #21
shlai
Hong Kong
Other than engine stalling at low RPM, I also notice my car burn more gas and feels less powerful. I open the air filter to see if any air duct cracks as this was my problem in my old E85. I took a photo of the air duct after removing the air filter and I found this:
      07-04-2014, 02:25 PM   #22
STR3T
STR3T's Avatar
40
Drives: 2020 Z4 sDrive30i
Whoa....How can I check for error codes via BT?
zpost
