New 2009 2010 BMW Z4 - ZPOST
      04-08-2014, 06:29 PM   #1
jingnai2
Drives: 2014 Z4 35is
Questions about our 19 inch OEM wheels
Does anyone know how much they weight and what company made those wheels for BMW, and are they really good for track race?
      04-08-2014, 06:46 PM   #2
CedarZ4
Drives: G05 M50i, Tesla M3P
If I'm not mistaken, speculations are that OEM BMW wheels are BBS (someone correct me). For style 326, the front wheels are 13.95kg (30.75lbs) and the rears are 13.8kg (30.42lbs). In regards to the track, they are most likely low-pressure cast wheels. While they are ductile, if you are really a tracky getting a set of forged wheels might be worth it. That, and coming in at 30lbs they are quite heavy for 19s.
      04-08-2014, 07:06 PM   #3
RaceTruk
Drives: F13 M6
Some wheels are made by bbs
Pretty sure these are not.
Regardless OEM bbs means they are strong.
That in fact means they are heavy as bricks usually when it comes to OEM wheels.
      04-09-2014, 02:22 AM   #4
nicknaz
nicknaz's Avatar
3188
Drives: C6Z
I don't know the company that made that wheel... my understanding is that BMW uses multiple suppliers, and some known suppliers are BBS, Ronal, Hayes-Lammerz, Borbet.
All of them are high quality suppliers
What do you mean by 'really great for track'? They are strong and high quality. Not the lightest as others have mentioned but I personally would trust BMW OEM wheels on my car over most aftermarket wheels
      04-09-2014, 08:28 AM   #5
Kessler35is
Drives: 2015 F15 50i, 2016 E89 35is
2016 Z4 35is  [0.00]
2015 X5 50i  [0.00]
You will get a much better selection of tires if you move to a 17 or 18 inch wheel, also the tires get cheaper. You will want a set of road and a set of track wheel's/tires.
IMO you do not want low profile tires when you are on the track, look at race cars and see how many run large wheels and low profile, you need sidewall for support and dampening.
Just make sure the wheels you pick have full clearance for the brakes and you can go full lock on the steering with out rubbing.
zpost
