04-08-2014, 12:55 PM | #1 |
Rep 150
Does the BMS modified clutch valve really extend the life of the clutch?
I am not sure if I am posting in the right section but here it is, I have been reading good reviews about the day and night difference with the BMS modified clutch valve (CDV?) but does it really extend the life of the clutch as advertised on the description? I can only imagine fully engaging the clutch would create more wear to it if anything. I don't understand the engineering of it, would anyone be able to answer this?
04-08-2014, 01:42 PM | #2 |
Rep 374
The whole point of the CDV is to keep transmission safe by slowing down how fast the clutch can engage. However, this adds more wear on the clutch. If the BMS modified clutch valve doesn't have as small of a restriction (i.e. acts like a CDV delete), then it should (theoretically) improve clutch life.
New Car: 2019 Porsche 718 Cayman GTS | Stock for now Old Car: 2013 BMW 128i | 6MT | BMW Performance Grills | CDV Delete | SSK | Performance Exhaust | M3 RSFB | TCKR DA |
04-10-2014, 04:59 PM | #3 | |
Rep 150
04-10-2014, 10:02 PM | #4 |
Rep 131
^^^ yes because your clutch would grind more as it completely engages slowly, instead of faster engagement.....its kind of like if you are driving lets say 50mph and you want to do a complete stop. Option A is you slowly brake (lets say for 10 seconds duration) till you completely stop. or Option B would be a much hard braking (lets say 3 seconds duration)...so in this case your brake pads would wear off more in Option A braking as opposed to Option B braking....lol, i hope that make sense.
04-11-2014, 12:41 PM | #5 |
2293
Rep 12,569
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Theoretically yes but if you still shift like a noob, then no lol.
04-11-2014, 04:45 PM | #6 | |
Rep 150
I am no pro but definitely not a noob, I would say lol. |
06-01-2014, 10:40 PM | #7 |
191
Rep 506
Drives: 2010 128i 6MT Sport Pkg. 18"
Less slip is going to give you less wear. CDV delete was the best thing I ever did to this car. Stock setup was the worst clutch engagement I have experienced in 40+ years of driving manual trans. cars.
06-01-2014, 10:58 PM | #8 | |
Rep 902
CDV delete + Clutch stop = .............. a normal manual transmission driving experience! |
06-03-2014, 10:04 AM | #9 |
Resident Tamed Racing Driver
298
Rep 4,697
Reduces clutch wear, but at the expense of drivetrain wear if you aren't the best manual driver.
It exists for a reason.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
