11-30-2013, 04:00 AM | #1 |
1718
Rep 5,110
US Curb and EU Kerb weights, an attempt at clarifying the differences.
Featured on BIMMERPOST.com As this is a work in progress, it might not have all relevant info at the moment, there might be inaccuracies or contradictions. I welcome any constructive input to make this info as accurate, reliable and useful as possible Summary: Weight standards currently used by BMW and other German/European brands on their official web sites. EU/Germany: 1. Leergewicht EU ( Car with 90% fuel, 68kg driver, 7kg luggage (75kg). Latest EU definition uses only driver @ 75kg ) 2. Leergewicht DIN ( Car with 90% fuel, no driver, no luggage ) USA: 1. Curb weight ( Inconsistent reporting, with or without driver, unknown and inconsistent equipment level ). Recommendation: Use the European standards for apples to apples comparison. For cars that lack European weights, further research is needed to determine what is included in that cars stated US "Curb weight". Summary of definitions: US Curb Weight:
EU Kerb Weight/Leergewicht EG: Latest EU definition of "mass in running order" (curb weight) according to 1230/2012/EEC:
Previous EU definition of mass of the vehicle:
DIN/ISO Kerb Weight/Leergewicht DIN:
A few real life examples: Example 1: E92 M3
Here we can see that the US and EU weight doesn't match each other and there is a good reason why they don't. EU weight of 1675kg includes DCT as that is stated in the BMW info, 1655kg is with the manual 6-speed. According to US legislation curb weight shall include options that is expected to be installed in at least 33% of vehicles sold. That means added weight. And US fuel level is 100% as opposed to EU 90%, which adds 6,3l of fuel in the E92. So, if we take the EU 1655kg weight as a base (since that is the lightest known version of the std. E92 M3), the following makes the US weight end up at 1681kg:
Example 2: F15 X5 and Cayenne If we take the new X5 X-drive 35i for example these are the reported weights:
Here the 40 lbs US curb weight above Leergewicht EG (4680 vs 4640lbs) must again be due to the fact that US curb weight shall include optional equipment expected to be sold in more than 33% of the sold vehicles.. Now for comparison let's take the Porsche Cayenne.
So if you just used the US curb weight you would get that the Cayenne is 4680 - 4398 = 282lbs / 128kg lighter (than the X5). But look closer and you can see that the Cayenne's US curb weight reported is that of it's Leergewicht DIN (without driver and luggage) while the X5 is (Leergewicht EG + 40 lbs) which includes driver (75kg) and 40lbs optional equipment. (The Cayenne is specified as a unique model with the tiptronic gearbox and is 35kg heavier than the manual car, which is also one difference between the Cayenne and X5.) When comparing apples to apples the real difference is 4475 - 4398 = 77 lbs / 35kg. Which "strangely" also is the exact weight of the Tiptronic version of the Cayenne. So a Tiptronic Cayenne and a X5 35i, with similar transmissions, have the exact same curb weight/leergewicht I.e US reported curb weight is not consistent but Leergewicht EG and DIN are consistent between these two German brands (just remember to compare comparable models/equipment levels). UPDATE 12. June 2014: The EU type approval number for the M3/M4 is: e1*2007/46*0377*06 and e1*2007/46*0377*07 These are the minimum weights listed in the type approval specs: M3 DCT - 1560kg M3 6MT - 1520kg M4 DCT - 1537kg M4 6MT - 1497kg -------------------------------------------------------------------------------- Definitions have been removed from this post, but can be found here: http://f80.bimmerpost.com/forums/sho...7&postcount=49 List of edits: 30.11.2013: The first sketch of the write up with only EU/DIN/ISO and US curb weights 01.12.2013: Added the new EU-legislation that repeals 92/21/EEC 02.12.2013: Added Leergewicht EG and Leergewicht DIN nomenclature to the definitions as well as added soltice's BMW X5 and Porsche examples 03.12.2013: Removed definitions from OP (can now be found in post #49 - see link below) 03.12.2013: Thanks to swamp2 and solstice for constructive input 12.06.2014: Added type approval numbers and listed minimum curb weights from type approval spec Last edited by Boss330; 06-12-2014 at 12:14 PM.. |
11-30-2013, 06:45 AM | #3 |
21121
Rep 20,741
Drives: 2021 911 turbo
So does the US curb weight inlude the driver?
11-30-2013, 08:18 AM | #4 | |||
1718
Rep 5,110
From the definition used by US authorities (and also Dept of Defence) Curb Weight does not include driver. The US definition of driver weight is 68kg.
http://www.nhtsa.gov/cars/rules/ruli...ervehicle.html The NHTSA defines curb weight as follows: Quote:
Same as FMVSS: http://www.fmcsa.dot.gov/rules-regul...aspx?reg=571.3 And: Quote:
And from this mini guide to FMVSS regs: Quote:
11-30-2013, 12:08 PM | #5 |
5458
Rep 7,037
The summary is that you need to check each curb weight number given by the manufaturer in the US. Some include the driver, i.e they report "Unladen EU" weight others report the US definiton or Unladen DIN without driver. It's even more confusing because the same manufacturer is not neccessarily consistent in how they report curb weight in the US data sheets.
This is the standards compressed: Curb Weight = Weight of Car with standard accessories, full fluids, no driver Unladen EU Weight = Weight of Car with 90% fuel, 68 kg driver, 7 kg cargo Unladen DIN Weight = Weight of Car with 90% fuel, no driver, no cargo 1 US Gallon = 3.8 liters Weight of 1 US Gallon of Gasoline = 6.35 pounds (2.87 kg) Weight of 1 liter of Gasoline = 1.67 pounds (0.76 kg) --------------------- We refer a lot to the E92 M3 here. Unladen EU ( with driver and luggage ): 1655 kg / 3649 lbs US reported Curb weight: 3704 lbs Here BMW has obviously inlcuded the driver and luggage in their reported US Curb weight. The 55 lbs difference could be DCT. ------------------- The number we have for the M4 is 1500kg Unladen DIN. The E92 M3 Unlade DIN is 1655 - 68 - 7 = 1580 kg or exactly 80kg more than the M4. -------------------- Last edited by solstice; 11-30-2013 at 01:25 PM.. |
11-30-2013, 04:55 PM | #7 |
5458
Rep 7,037
If the M4's DCT is 70 kg heavier than the M4's manual then yes. 70kg sounds like a lot though. Is the new DCT really that much heavier than the new MT? The E92 M3 difference between MT and DCT was around 22 kg I think.
11-30-2013, 10:53 PM | #9 |
611
Rep 10,407
It appears there are 2 answers. There are official/governmental definitions and then there is whatever the manufacturer wishes to do (no surprise). In the case of BMW it appears quite certain that the numbers include driver but BMW typically uses "Unladen weight" in US specification sheets.
Anything to add on this "unladen" thing Boss330?
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
11-30-2013, 10:54 PM | #10 |
611
Rep 10,407
Boss330? Thanks so much for the write up. It is very useful. I will suggest it as a sticky.
Max Well4746.50 |
11-30-2013, 10:59 PM | #11 | |
611
Rep 10,407
All BMW numbers on the US web site now appear to be "Unladen", however, I'm sure I've seen them use other specifications in the past.
11-30-2013, 11:19 PM | #12 | |
21121
Rep 20,741
The DCT is 20kg (45lb) heavier on the E9X plus they were able to shave 12kg (26lb) on the F8X 6MT for a 32kg difference (70lb). This is assuming that the new DCT is not heavier than the previous gen. |
12-01-2013, 12:54 AM | #13 |
206
Rep 7,298
Arent the numbers floating around 70kg though? I do agree with you though more than a hundred pound difference is quite steep.
Im just wondering if this weight savings is just a bunch of bullshit. All this mumbo jumbo on weight savings and its just how you spin a story. Thats all. |
12-01-2013, 12:54 AM | #14 | ||
206
Rep 7,298
12-01-2013, 01:01 AM | #15 | |
5458
Rep 7,037
If we take the new X5 X-drive 35i for example these are the reported weights: bmwusa.com: 4680 lbs Curb weight bmw.de: 2030kg / 4475 lbs Leergewicht DIN bmw.de 2105kg / 4640 lbs Leergewicht EG So for the X5 it looks similar to the E92 M3 where driver + luggage is included in the curb weight to get to a 40 lbs above Leergewicht EG. Now for comparison let's take the Porsche Cayenne. porsche.com/usa 4398 lbs Curb weight porsche.de 1995kg/ 4398 lbs Leergewicht DIN porsche.de 2070kg/ 4564 lbs Leergewicht EG So if you just used the US curb weight you would get that the Cayenne is 4680 - 4398 = 282 lbs ligther. But look closer and you can see that the Cayenne's curb weight reported is that of it's Leergewicht DIN ( without driver and luggage ) while the X5 is (Leergewicht EG + 40 lbs) which inlcudes driver and luggage. When comparing apples to apples the real difference is 4475 - 4398 = 77 lbs. I.e US reported curb weight is not consistent but Leergewicht EG and DIN are consistent between these two German brands. Last edited by solstice; 12-01-2013 at 02:09 AM.. |
Max Well4746.50 |
12-01-2013, 06:28 AM | #18 | |
1718
Rep 5,110
This is one of the things I will try to find out more about and whether the US manufacturers use different standards when stating curb weight. With the F8x it seems 100% clear that the 1495-1500kg curb weight is with 90% fuel, fluids and in the base Version, but WITHOUT driver. Which is a bit misleading since they allways use curb weight with driver elsewhere... |
12-01-2013, 06:45 AM | #19 | |
21121
Rep 20,741
12-01-2013, 07:34 AM | #20 |
1718
Rep 5,110
EDIT
Added the new EU legislation that repeals 92/21/EEC, and replaced it with commision regulation 1230/2012 that implements regulation 661/2009 with regards to masses and dimensions. |
12-01-2013, 01:39 PM | #21 |
504
Rep 3,446
Driver @ 75 kg, whoops, I am off spec.
See my photography at http://ronscubadiver.wordpress.com
12-01-2013, 01:52 PM | #22 |
Rep 1,489
Thanks for all this info, my head hurts/
-Diplomacy is saying, "nice doggie while trying to find a rock"-
07-Z4 coupe-Black/Black/6MT/sport/premium/X 04-M3 vert-Black/Imolla/6MT/Cold/Xenon/HK/ 06-M3 Coupe-Mystic/Black/6MT/ZCP/Xenon/HK/ 09-135i- AW/Bk-Lette/6MT/M-pac/Nav/Hi-Fi/Usb-Ipod/SOLD |
