09-11-2013, 03:06 PM | #1 |
Rep 221
Dealer Response to Auto Transmission Fluid Service Request
My car is a 2009 CPO 128i with automatic transmission and 53,300 miles. I called my local dealer to get a price for changing the transmission fluid and the response was that they don't generally offer that service because the system is sealed for life and requires no service.
When I asked if that meant that they literally would not do it, he said they would if I really wanted it but I would first have to agree not to hold BMW responsible in the event that the service stirred up existing dirt/particles which subsequently caused the transmission to malfunction. He said the price would be "about $800", with "about $400" of that going to the cost of the fluid, which he said is "very expensive". Anyone else have a different experience with their dealer on this subject?
2011 328i Coupe | Alpine White | Oyster/Black Dakota Leather | M Sport Package | Premium Package | iDrive | Harman Kardon Surround | Steptronic
09-11-2013, 03:26 PM | #3 |
Rep 388
I had the manual gearbox fluid and differential fluid changed at 1200 miles and had no problems with my dealer other than they had to order the gearbox fluid. I will get them changed again at 30,000 miles and every 30,000 miles thereafter.
09-11-2013, 04:02 PM | #4 |
84
Rep 1,623
Drives: Alpine White 128i Cabrio
There is a DIY on here about that I think, but I was wondering about going to a dealer to get it done also. I never asked because I feared of getting the same response. I believe ECS tuning sells a transmission fluid kit (I could be wrong, but I remember seeing it somewhere). And I don't think its $400.
09-11-2013, 04:05 PM | #5 |
1838
Rep 6,991
Drives: 15 F80 M3, 22 G01 X3 30i
Find a good Indy shop to do this - they're almost always less expensive than a dealer and carry good synthetic products that comply with BMW requirements. I did this with my previous E92 and had no issues at all.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
09-11-2013, 04:42 PM | #6 |
Turbo Power
50
Rep 364
LOL $400 for fluids? Seems like he is trying to screw you hard! Redline D4 ATF synthetic transmission fluid costs about $50 and an Indy shop near me said they will replace transmission and diff fluid for $95 labor. Don't get screwed by the dealer, find an Indy shop.
BSM 135i - CDV Delete | Bilstein | Eibach | M3 FSB | Whiteline
09-11-2013, 05:01 PM | #7 | |
Rep 221
09-11-2013, 11:07 PM | #8 |
Resident Tamed Racing Driver
298
Rep 4,697
You also need to replace the gasket, filter, often the pan, and all that crap along with the fluid. Auto trans fluid swaps are a bit more involved than manual, and considerably more expensive.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
09-12-2013, 08:08 AM | #9 |
Turbo Power
50
Rep 364
Did not know that you need to replace all that for an Auto. Glad I drive a 6MT. Even if you buy all those parts and have an Indy shop do the job, it would be around ~$300, not $800!
09-12-2013, 08:38 AM | #10 |
456
Rep 6,478
For 6AT swap the pan, gasket, and fluids, I did mine at 50K and will do it again at 100K. Redline D4 has been good to me. Going to the dealer for any sort of fluid swap is criminially dumb. Do not waste your money. ECS has a kit with everything you need including the filler plug.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
09-12-2013, 09:04 AM | #11 |
Rep 388
09-12-2013, 09:35 AM | #12 |
2293
Rep 12,569
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Keep in mind there's a difference between drain and fill vs flush. Your SA might be referring to a full flush of the entire system which is very difficult, costly and potentially harmful if not done properly. A simple drain and fill on the other hand is really easy. Don't recall what the latest version from BMW is (MTF-L1/2/3) but 1 jug is enough for 2 cars. I paid maybe $70 at a reputable indy and that include the cost of fluid.
09-12-2013, 10:27 AM | #13 | |
298
Rep 4,697
I'm just pointing out that it will not be $70 swap like in a 6MT car, expect a couple hundred in parts alone.
09-12-2013, 09:51 PM | #14 |
171
Rep 2,682
I did this myself at 100,000kms. Made a big difference to the smoothness of the shifts. Parts including fluid and pan (incl gasket, filter and magnet) with shipping came out to less than $400.
DIY - 135i/N54 Steptronic Automatic Transmission Fluid Flush and Service http://www.1addicts.com/forums/showthread.php?t=777083
09-15-2013, 01:00 PM | #15 |
Rep 1,035
BMW auto transmission fluid is VERY expensive. Its about $20+ per HALF litre. If you just want a drain and fill you are talking hundreds of $$ in just fluid. Plus gaskets etc.
Second- BMW trans fluid is lifetime fluid. There is no reason to change the Auto trans fluid. Only top off if you have a leak repaired, but there is no need to replace it. I have never seen a BMW auto trans fail due to fluid not being changed. I have seen many failures when putting all brand new fluid in there. There is a reason why BMW states its a lifetime fluid. I understand you are trying to do preventative maintenance, but there is a reason why the dealer wants you to sign an agreement that if something happens its not their fault. Because they have seen the same failures @ the dealership, that I have also seen. You do not need to change it on an Auto car period. I would save your $$ A manual car is completely different and should be changed. |
09-15-2013, 03:17 PM | #16 | |
84
Rep 1,623
09-15-2013, 03:32 PM | #17 |
European Editor
10616
Rep 22,992
For the DIY-er or to order the correct fluid for your trans... try these guys...
http://www.thectsc.com/
