08-26-2013, 06:18 PM | #1 |
Rep 96
Performance Friction Pads for 135i
I dont know why I didn't just post here from the beginning. Anyways, Speed Freaks (who is a Tier 1 PFC dealer) is working with PFC to finally get pads made for the stock 135i calipers. The options would be for the brand new 11 compound or the relatively new 08 compound.
Compound descriptions from PFC: NEW 11 Compound 11 Compound is a new generation sprint and medium distance friction —the ultimate in control, with superior disc conditioning. 11 compounds were developed from the 01 compound with improved bite, modulation, and release characteristics. It is ultra smooth and developed to reduce wheel locking at the end of a stop. Brake with confidence—brake with ultimate control and modulation. For many applications, 11 will replace the venerable 01 compound. Typical applications; Ideal use for medium-low grip venues where control and modulation is at a premium. Also racing venues where ABS systems are used, .11 can be used in a large spectrum of temperature ranges. 11’s wear is par with PFC’s legendary 01 compound. Virtually zero taper wear when raced in a properly designed race caliper. 08 Compound 08 compounds are one of PFC newest and have gained immediate favor in Endurance Sportscar, and GT racing due to its performance in applications where smooth initial bite is a must. 08 have a slight friction rise with temperature, excellent release and modulation characteristics. Very low abraded disc wear with a fine grey slate like disc finish, similar to 01. Despite its considerable performance, 08 wears the longest of all PFC pads and easily matches wear of the other competitors with much higher bite Typical applications: Ideal use for endurance where long wear is at a premium. Also racing venues where ABS systems are used. I would like to get a list going of who would like pads and the compound so please post up if you are interested! The most popular compound split is 08 compound front and rear or 11 compound front with 08 in the rear if you want a little more front bias for stickier EHP street tires and beyond. I will be leading the charge on this so feel free to PM me if you have any questions. Interested: 1. Sixle- 11 front / 11 rear? 2. jafo1701- 08 front / 08 rear Last edited by MMisencik157; 08-26-2013 at 09:24 PM.. |
08-26-2013, 07:48 PM | #2 |
Rep 257
08-26-2013, 09:29 PM | #3 |
Rep 96
09-03-2013, 01:23 PM | #5 |
2304
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.26] |
post this in the track section of bimmerforums, i'm sure there's a few e82 guys who track regularly.
09-04-2013, 01:14 AM | #6 |
Rep 96
10-13-2013, 09:48 AM | #7 |
2304
Rep 12,570
Any update?
