08-04-2013, 01:44 AM | #1 |
Rep 88
Can't enable/disable MDM mode
So I noticed I can't enable/disable MDM mode using the ESC button on the center console. I have it programmed into my M mode settings so I can turn it on that way. Any ideas why this could be happening? I am still able to use the ESC button to turn traction off fully by holding it down.
08-04-2013, 03:11 AM | #2 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Well, let's start with there is no such thing ESC. There is EDC, which is Electronic Damper Control. And there is DSC, which is Digital Stability Control, which is, I assume, what you meant. The console button is actually labeled "DSC Off", which is what it does. Using that button, you can turn DSC off, (and back on) and nothing else. MDM is only accessable through the "M" button, and then only if you have it programmed to do so when you push the "M" button.
So, the short answer is, there is nothing wrong with your car, that is how it works.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
08-04-2013, 07:23 AM | #4 | |
3388
Rep 7,542
Edited to say dynamic
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
08-04-2013, 09:47 AM | #5 |
369
Rep 1,887
Got me. I was close.
08-04-2013, 10:29 PM | #8 |
369
Rep 1,887
I run in MDM most of the time... Maximum Douchebag Mode.
08-04-2013, 10:55 PM | #9 |
209
Rep 7,298
