07-24-2013, 01:35 AM | #1 | |
611
Rep 10,407
BMW M3/M4 s55 Engine RPM Redline Projections via Technical Sound Analysis
Featured on BIMMERPOST.com Quote:
I began testing a couple of dyno recordings and fairly quickly found an E92 M3 video and V12 Aston with 6800 rpm redline. I recorded the sounds (just from crappy Youtube videos) and then did a Fourier transform to get the spectral content. E92 M3 frequency peak at redline should be 560 Hz, I measured 570 Hz. V12 Aston is 680 Hz theoretical, 688 observed. In both cases "the" peak was actually the second peak not the first. Those results are within about 2%. The method absolutely can work. Moving on the the M4 video I'm not entirely sure that around the 3:07 time mark he get's a true redline shift. I think this is at Galgenkopf, what do you think? Based on that he is indeed most likely in 3rd and I agree that the peak speed at redline should be around 90-97 mph (depending both on gearing and redline). Getting a true discernible peak in the spectral results was not straight forward as compared to the dyno runs (to be expected) and thus my results are a range of frequencies from 345-365 Hz. The capture below from ~5.5-6.0 seconds is showing a discernible (first) peak at 358 Hz. Combining that with the Doppler effect from 90-97 mph gives a source frequency in the range of about 385 - 415 Hz. That in turn translates to 7700-8300 rpm! This is entirely consistent with my prior estimate of a peak redline of 7700 rpm. UPDATE 7/26: Thanks to some additional insights from post below by bradleyland I am revising my final rpm estimate down considerably to 7250-7550 rpm. In short my audio capture was too low in quality. I did recheck a couple cases of dynos mentioned above using the new technique. For instance the V12 Aston came in at 6770 vs. 6800 quoted, less than 0.5% difference. Given the F10 M5s redline in particular, 7200 rpm, I just don't think 8000 (Admin edit: rumor is close to 8000 rpm) is possible. There is also the prior problem of resolving the inconsistency of an 8000 rpm redline, about 400 ft lb of torque and about the same power as the existing M3... To be more accurate and more certain we need a video of a clear redline shift with good audio quality and minimal Doppler (i.e. camera right by shift point). Anyone?
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | Last edited by swamp2; 07-26-2013 at 07:55 PM.. |
07-24-2013, 06:06 AM | #2 |
Rep 1,399
M3/M4 s55 Engine Redline Projections from Technical Sound Analysis
07-24-2013, 07:12 AM | #3 |
21121
Rep 20,741
Drives: 2021 911 turbo
07-24-2013, 07:26 AM | #4 |
Moderator
7516
Rep 19,368
Swamp, if you were my professor I would love your lectures but loathe your exams. That's very impressive work - gotta give props to both you and the guy that suggested the idea. I'll be even more impressed if your numbers match the production engine.
I wonder if the engine sounds from development-M5 track footage consistently yield 7200RPM. It would be an example (or examples) that are close to home. |
07-24-2013, 11:02 AM | #5 | |
611
Rep 10,407
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK | | Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors | | Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels | | XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit | |
07-24-2013, 08:45 PM | #8 |
Rep 329
Drives: 08' 335i, ZHP 330i
I have a go pro video from the front number of the new m6 driven to redline on a track if it would help.
T |
07-25-2013, 02:07 AM | #9 |
611
Rep 10,407
Thanks, might be fine to try but I'd prefer something a bit closer to a spectator filmed one like the video the analysis is based on.
07-25-2013, 02:08 AM | #10 |
611
Rep 10,407
I'm a recovering physicist and recovering engineer. Now I sell engineering software.
07-25-2013, 12:02 PM | #11 |
432
Rep 4,567
Big props to you Swamp. I'll be curious to see how accurate your projections are once the car is officially unveiled.
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
07-25-2013, 01:08 PM | #13 |
424
Rep 4,709
I'm no expert in this field, but aren't there still a number of unknowns you'd need to know before making these calculations? I see you make an estimate on speed, but wouldn't gearing and exhaust acoustics also come into play? Also, it's probably a safe assumption, but still an assumption that the car is shifting at redline.
Excellent analysis though. |
07-25-2013, 01:53 PM | #14 |
1770
Rep 7,652
Wow! Great work. Look forward to seeing the comparison between your analysis on the production S55.
07-25-2013, 02:03 PM | #15 |
1726
Rep 3,205
Great job!
07-25-2013, 02:25 PM | #16 |
Rep 1,231
Very impressive! Thank you!
07-25-2013, 02:30 PM | #17 |
that's what SHE said!
75
Rep 1,163
He stayed at a Holiday Inn Express last night
07-25-2013, 02:45 PM | #19 |
4450
Rep 7,594
Drives: '19 M2C
Dang-it you beat me toooo it!
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
07-25-2013, 02:55 PM | #20 |
5458
Rep 7,037
Nice!
Here's a pretty clean audio of the only production I6 turbo M car, it's in cabin but it would be interresting to see what top rpm the SW spits out. 4:24 and 4:28 for example seems like possible redline shifts. ( if you watch the whole thing you will also see two M3s showing who the daddy is ) Last edited by solstice; 07-25-2013 at 03:00 PM.. |
