05-16-2013, 08:36 AM | #1 |
Rep 168
Custom One-Off Manifolds - SR-Racing
This is a one-off Exhaust Manifold made for M5 SR-R Project This was sent to me a few hours ago by the guys @ SR-Racing... Sorry for not posting a clear pic Stock on the left (grey) Manufacturer: TripleDz Motorsport
05-16-2013, 09:51 AM | #4 |
Rep 168
Performance wise i guess, i dont have any details i just got the pics and posted them
05-16-2013, 09:52 AM | #5 |
Rep 168
Ill try to get more pics. but they're good as of what i heard
05-16-2013, 10:00 AM | #6 |
Curve Thrasher
623
Rep 3,773
Those r some ugly azz welds.
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run |
05-16-2013, 10:19 AM | #8 |
Rep 168
Its about the power not the welds, im not going to lay on bed with those LOL
Plus, those are perfectly welded, go and show any professional Manifold manufacturer and tell us what he thinks. Those are hand tig welds that are great! We were waiting for other tuners to come out with manifolds, but nobody made any. TripleDz are the first to to do Manifolds for SR-R. Noobs dont know how perfectly welded manifolds look like
05-16-2013, 10:33 AM | #10 |
2873
Rep 7,885
Oh sorry nevermind. I was confused by the picture. I see which ones are stock and which ones are the aftermarket. Looks like the ones on the right have a bigger diameter piping.
05-16-2013, 10:35 AM | #11 |
5458
Rep 8,815
Apparently you must be a noob then.
This is what legit welds looks like. I don't doubt they make power and as long as the welds don't leak you are fine but still doesn't change the fact that the welds look like crap
05-16-2013, 10:40 AM | #12 |
Rep 168
Yes they are, of what i heard from the guys in SR-Racing, they will install those set of manifolds on their R&D M5 engine using a superflow engine dyno at TripleDz before they install it on the project car's engine.
05-16-2013, 10:51 AM | #13 | |
Rep 168
Those are perfect welds + SR-R want something fast and reliable not a barbie car.
05-16-2013, 11:30 AM | #14 |
Rep 978
Ditto on the welds. The guys in my fabrication shop can show you some nice tig welds.
2021 M340i
2020 X3 M40i - her car 2019 M5, AW, DP's, MSR CAI, BM3, SOLD 2020 Chev. ZR2 Bison truck, Daily Driver |
05-16-2013, 01:39 PM | #15 |
1718
Rep 5,110
Disregarding the welds, those manifolds look like they are going to increase flow quite a bit
Larger diameter and more smooth bends should help exhaust flow quite a bit. As long as the welds are strong enough thats what matters, after all the exhaust manifolds are not visible at all on this engine. |
05-16-2013, 05:02 PM | #16 |
Perennial PFC
336
Rep 1,275
I'm not sure what the bellows function is on the stock exhaust tubes, but my guess would be to minimize expansion and contraction forces on the connected mounting surfaces. For a race car perhaps not as important, but for everyday use with many heating and cooling cycles, the solid tubes might pose a problem?
05-16-2013, 06:47 PM | #17 |
Curve Thrasher
623
Rep 3,773
Well, If you think they are perfectly welded......yes, it's about the power I agree.....I think I know what perfect welds look like expecially since our fab does this all day everyday. Tig, stick or whatever so no noob here especially since I weld also. Come on man, you got to admit they are ugly..I wasn't trying to be mean here and I'm not taking anything away from the product. I just know those welds could have looked tons better.
Best wishes.
Country run |
05-16-2013, 10:18 PM | #18 |
Rep 1,489
How much went into the design spec on these? I.e., diameter of the pipe vs. the length, engine speeds and turbo specifications? I am assuming that the manufacturer designed, tested, and refined these using CFD...LOL. The cross-bank manifold design of the S63tu is critical to the engine performance.
Good luck with those. I'll keep my "Barbie" stock exhaust manifolds, designed and manufactured by the good folks at Boysen.
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
05-16-2013, 10:46 PM | #19 | |
2873
Rep 7,885
05-17-2013, 04:05 AM | #20 |
1718
Rep 5,110
Yes, aftermarket manifolds have some drawbacks that don't come with the stock manifolds. NVH, durability etc will probably suffer. But if you want more power, stock manifolds are often one of the restrictions that has to be modified to go over a certain limit.
Remember that the stock manifolds are not designed just for maximum power, but also to keep exhaust gas speed at an optimum even at lower revs to decrease lag. To accomplish this the tube diameter and design is a deciding factor. On my second car (Sierra Cosworth) the factory had two exhaust manifold designs. The first one was for homologation purposes and is good for around 500hp, the later design which reduces lag significantly is only godd for around 400hp. But if you want to go beyond 500hp, you will have to go for an aftermarket tubular design to get enough exhaust flow. Since the stock manifolds on the M5 is good for over 700hp (MHR) it would only be relevant to change the manifolds if you want to do an extreme M5 approaching 8-900hp. |
05-17-2013, 05:56 AM | #21 | |
Rep 168
05-17-2013, 06:04 AM | #22 | |
Rep 168
Ill keep you guys updated anyway. One more thing regarding the Turbo Upgrade, unfortunately the guys that upgraded the turbos didnt do a really good job.. So the guys at SR-R sent the turbos to another manufacturer... just an upgrade.. Or maybe a gt30x? not really sure..
