M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding
      03-02-2013, 10:13 PM   #1
nugent
nugent's Avatar
Drives: f10 m5
Want to improve Active Sound Design by coding?
Try the following below. The result is a deeper more baritone exhaust note. I like it. personally, I don't want to attract any more attention with an aftermarket exhaust. I do like aural simulation though, in every sense of the word. cheers.
Hi all,
I'm new to this community and hope I'm not making any mistakes with this very first posting...
So here's my contribution: As the lucky owner of a new M5 F10 I needed a way to disable the 'Active Sound' module because it really disturbed me. Pulling the fuse was not an option as this disabled the complete sound system and removing the ASD box in the trunk would be to invasive.
That's what I did using E-Sys:
There's a special ASD module that has several preconditions before becoming active (see the 'Aktivbedingung' folder in the screenshot): Only certain models will activate the ASD. Those models are listed as functions, e.g. 'F010 true()'. So I looked a little bit lower in the tree and changed
3000 ASD-Configuration - Funktionen - Baureihe to F021
As you can see on the screenshot, the F21 model won't activate the ASD.
I made several tests and compared to pulling the fuse so I'm 100% sure this little modification really disabled the ASD in my car :-)
BTW, for those willing to change the sound: There's also an option 'Motor' where you can change the installed engine (for Diesel sound try N57D30). I haven't tested all these parameters - I'm glad that nasty module is switched off
Best regards
e92 m3 6MT, RS4 6MT, S4 Avant 6MT, WRX 5MT, Corsica
      03-31-2013, 08:09 PM   #2
maem2501
maem2501's Avatar
Drives: 2013 Alpine White M5
Just in case If you need tech info
2013 F10 Alpine White
2013 LS460L
2011 Audi Q7
      04-02-2013, 12:05 AM   #3
dreamspeed
dreamspeed's Avatar
Drives: 6MT
Wait, so you can make your car sound like different cars with this software edit?
      02-10-2014, 04:04 AM   #4
chizi
chizi's Avatar
United Arab Emirates
Drives: BMW M5 2012 Hamann
my car does not have F021
m5post
