02-07-2013, 04:31 PM | #1 |
Rep 74
Dyno'd (stock air box/block off plates/charcoal filter delete)
Went to get another dyno after dealer installed plates..sure enough i was right and the call feels great now!
My mods are RPI GTS exhaust and RPI air scoops which were on all the runs. run#8 is with stock air box on 1/31 temp: 77 degrees run#16 is with block off plates on 2/6 temp: 65 degrees run #19 is with Charcoal filter delete
Current: 2014 M6GC CP and 2015 M3
Past: 2013 M5, 2012 E63, 2011 panamera turbo, 2010 E63, 2010 GTR, 2009 C63, 2008 M5 |
02-07-2013, 04:33 PM | #2 |
Rep 74
We had to do few extra runs before we got started yesterday as i couldn't get the
car off the MDM mode.
02-07-2013, 04:48 PM | #3 |
Knight Commander
559
Rep 5,948
Drives: 2014 911 Turbo S
Garage List 2014 Porsche 911 Tu ... [10.00]
2015 Mercedes-Benz ... [0.00] 2015 Jaguar F Type R [0.00] 2014 BMW M5 [0.00] |
Wow. I need the new air box and the charcoal filter delete.
Bradone1 any chance your service advisor at South BMW can help us out?
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450 Ordered: EQS580, BMW IX, Lucid Air Touring, Corvette Stingray |
02-07-2013, 05:21 PM | #5 | |
Rep 1,489
Current: '16 GT4
Past ///Ms: '13 F10 M5, Alpine Weiss III/Sakhir Orange Full '10 E60 M5, Space Gray/Black |
02-07-2013, 05:29 PM | #6 |
2873
Rep 7,885
I can't see the pictures from my work computer. How much horsepower change was there from the Charcoal Filter delete? Can someone post this for me. Thanks!
02-07-2013, 05:32 PM | #7 |
Rep 280
run#8 is with stock air box on 1/31 temp: 77 degrees - HP: 496.61 TQ: 468.59
run#16 is with block off plates on 2/6 temp: 65 degrees HP: 536.00 TQ: 517.03 run #19 is with Charcoal filter delete HP: 551.47 TQ: 532.39 |
02-07-2013, 05:38 PM | #8 |
19371
Rep 10,167
pardon the ignorance, whats with the plates thing???
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
02-07-2013, 05:48 PM | #9 |
Rep 147
Some of the airboxes were coming off the production line with holes in the bottom of them. Then they started to add silver plates to cover the holes. Seems like most of the later built cars had the plates, mine does.
02-07-2013, 05:50 PM | #10 | |
19371
Rep 10,167
Oh ok thanks---- mine is Sept build--- I think Im ok- But Ill check.
02-07-2013, 05:59 PM | #11 |
871
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
So if I'm understanding this correctly about 625 crank hp? Seems high for stock ecu with exhaust, scoops and plates? But very impressive. Were these #'s "corrected" on the graph?
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
02-07-2013, 06:07 PM | #12 |
19371
Rep 10,167
According to the top right it looks uncorrected (non SAE)....
02-07-2013, 06:08 PM | #13 |
Perennial PFC
336
Rep 1,275
Since my airbox has a snorkel instead of a hole or a block off plate, and the build date was the end of November 2012, I wonder what BMW had in mind as the final design of the airbox? Has anyone with a later build date taken their airbox apart? Why would BMW leave the hole initially and then block it off completely, only to add the snorkel later?
02-07-2013, 07:20 PM | #15 |
Rep 1,341
Drives: 2013 M5 SSII
15hp for filter delete?
That's crazy
02-07-2013, 07:35 PM | #16 |
19371
Rep 10,167
Heard. I removed mine and I did feel the car was stronger... he ran his car 3 runs after the block plate was added so maybe the car was still adapting and the filters showed gains they didnt deserve?
02-07-2013, 08:20 PM | #18 |
154
Rep 3,041
I don't find it so hard. Actually, the numbers he is posting after installing the plates reflect ACTUAL numbers recorded on stock F10s by many people. Seems to be becoming pretty common knowledge that BMW grossly understated the HP and Torque on the stock cars. Likely that the hole in his box "took away" and the plates simply restored the power.
Also, the charcoal deletes do seem to work. I did mine and it feels a bit more "loosened up" the same way it did on my E60. I don't know about necessarily 15 hp but it is enough to be noticed. |
02-07-2013, 08:42 PM | #19 |
103
Rep 1,520
I'm also skeptical.
Same time between runs? Same fans etc? I can Make similar gains by doing some hot heat soaked runs then doing a cold run. Not to question your credibility but just curious on the other variables. I've even dyno'd it without any exhaust on to see if these overpriced exhausts had any real gains. |
02-07-2013, 09:43 PM | #20 |
2873
Rep 7,885
I know! This might prove my hypothesis correct.
I removed my charcoal filters tonight and also found out that I have the block off plates. My car is an August 2012 build. Here's some low quality iPhone pix for your viewing pleasure. After I removed the stupid environmentalist filters, I went for a test drive and raced a riced out civic or two. The results of my drive were excellent. The butt dyno was detecting appreciable gains and I felt like I could hear the turbos a little better. Prolly all in my head though or this case in my butt. Lol!
02-07-2013, 09:54 PM | #21 |
Boats & Hoes
21
Rep 345
...... Without a video of each run with temps, IAT,EGT, Ambient and humidity. Those are really far fetched numbers for the changes made... Tuning and full exhaust are bringing the same kind of numbers as the block off plate. 40 HP from a block off plate that should do lil to no difference on a dyno, with a fan blowing in to the RPI air ducts.. Unless the first run or runs were with no fans or some other change. How can removing a thin layer of filter bring an amazing 15 HP and completely removing the filter or putting on the gruppe M intake only yield the same results. Your first change (Plates) restricts the amount of flow to the filter and the second Removing the C filter helps flow more air.... How do they compound to make more power rather then cancel each other out?...
Sorry to be a skeptic but seems unusual to yield such large results on stock software and to gain TQ and HP both times from opposite changes, seems to good to be true. Aloha Alex
Change is inevitable Progress Is optional
02-07-2013, 10:11 PM | #22 | |
Boats & Hoes
21
Rep 345
This is kind of my point with out the extra filter you hear a difference.. If you take off the plates you will hear similar sound... So how can adding more air and restricting the air not negate each other? Especially on a none heat soaked car on a dyno with proper air flow.... 50+ HP and 70+ TQ from two small mods on a stock intake.....??? SAY WHAT???? No tune no exhaust change... how could an air pump be so poorly designed from factory? Aloha Alex
