12-25-2012, 12:40 PM | #1 |
53
Rep 563
I'm leaning heavily towards the axle-back Eisenmann race with 90mm tips. This setup removes the valves that control the exhaust passage at the rear. My questions are; what does that valve really do? Is it just noise control or does it add back-pressure at low rpm for fuel economy or pressure at part throttle for low RPM torque? How will the computer react to the missing valve? Thoughts?
12-25-2012, 12:43 PM | #2 |
871
Rep 1,758
Drives: 30Jahre M5 plus a few more M's
Garage List 2022 BMW M5 CS [0.00]
2020 BMW M340i Xdrive [0.00] 2019 BMW M2 Competi ... [0.00] 2003 BMW DINAN S3 M5 [0.00] 2017 BMW 30 Jahre M3 [0.00] 2016 BMW M4 GTS [0.00] 2015 BMW 30 Jahre M5 [0.00] 1995 BMW M3 [0.00] |
No negative effects. I think the valve is closed upon cold startup to help the cats warm up faster?
Current non-BMW's
20 Jeep Grand Cherokee 03 Cooper S (Maxi Tuned 50bhp) 60 Impala (43k orig mi) 15 Turbo S (Kobb tune and Kline exhaust) |
12-25-2012, 12:59 PM | #3 | |
2871
Rep 11,374
The valves are in place to reduce emissions during start up. Just make sure that the vacuum lines are plugged during the install or you will get a CEL. My installer uses a small drop of adhesive and two small license plate size screws to block the line.
