05-05-2012, 06:42 PM | #1 |
Rep 1,448
Drives: M2
neg terminal of battery
ok, retard question here.
Im trying to disconnect the neg terminal of the battery but cant seem to get it off. I've loosened the nut but its still stuck...? |
05-05-2012, 07:09 PM | #2 |
Rep 1,293
Back off the nut about 80% but keep it attached to the nut. Tap down on the nut lightly then lightly pry the clamp apart with a flat head screwdriver. Rock the clamp back and forth and it should come off.
05-05-2012, 10:58 PM | #4 |
Rep 1,448
Drives: M2
Thanks for the replies guys... hmm but it just wont loosen enough .... hmmm
05-05-2012, 11:02 PM | #5 | |
2820
Rep 7,640
Its made from lead, so should separate quite easy.. If need be, hold onto the clamp/cable with a pair of multi grips for added stability whilst separating the clamp.. |
05-06-2012, 06:15 PM | #8 |
Rep 1,448
Drives: M2
Eventually got it off with the aid of a flat head.
thanks guys. |
