ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      04-20-2012, 08:36 AM   #1
mshanno1
Drives: 2007 M Coupe
Rough Idle
http://www.youtube.com/watch?v=_l6dt...hLx6GMrwxwptA=
Has anyone experienced this before, or know what a likely cause could be. In the video you can see that the RPMs dont really fluctuate, but my hand is shaking from the car shaking so much. The phone was stabalized on the steering wheel.
Any thoughts?
      04-20-2012, 09:09 AM   #2
MHeavNC
Turd in the Punch Bowl
MHeavNC's Avatar
Drives: 2007 Z4 3.0i /// 2008 M Coupe
Have the motor mount bolts checked.. Something may be loose allowing vibrations to make you feel like it may be idling rough..
      04-20-2012, 09:18 AM   #3
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Run a bottle or two of techron concentrate back-to-back and see if it helps. Could be bad gas as well that this is a cheap check.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
zpost
