04-16-2012, 04:50 AM | #1 |
Rep 693
Worn M3 Tesion Strut
Went in to get a wheel alignment done to my specs because of the m3 suspension components and i did noticed steering was following the ruts in the road a bit and under heavy braking, but just putting it down to wearing of the tyres.
Suspension tecko took the car for a run and said something is wrong with the front suspension and put it on a special machine which tests the front suspension and sure enough got under the car and the left side wheel tension strut had no play, but the drivers side had so much play the wheel was moving about 2'' So much for stronger M3 bushes only done about 15000 kls Just ordered a new set from the usa.
THE BEAST MHD Flash Tune /M3 suspension/Forge Intercooler/Alpina B3 AT Flash/Bilstein B4 Suspension/BMW OEM M3 Steering Wheel and DCT Paddles/LUX V4 Angel Eyes/CIC Retrofitted
04-16-2012, 05:23 AM | #3 |
Rep 693
HI TIM
Fulcrums at stafford they set up my front negative camber spot on -1.8 and -1.4 with the M3 struts Haven't ordered the M3 rear bushes yet wasn't expecting this.
04-16-2012, 05:39 AM | #4 |
398
Rep 9,156
That's not good at all! So what did you end up replacing exactly? Would it be covered under some kind of warranty? I also go to Fulcrum Stafford, Terry knows his stuff, top bloke highly recommended.
04-16-2012, 05:39 AM | #5 |
44
Rep 1,883
Unless you've got camber plates the camber is not really adjustable. -1.8/1.4 must just be the way it worked out with the new links. Mine worked out as around -1.3/1.0 with the M3 links I think. I've got a Fulcrum printout somewhere from when they came to Lakeside and corner weighted & check the camber on my car.
Let me know if you're ordering any links etc. I'm still keen to order all the rear bushes, links & swaybar. Taa.
Driving - Manual E90 M3 (Melbourne Red/Black).
Riding - BMW R1200RS Sport. |
04-16-2012, 06:18 AM | #6 |
Rep 693
Replacing the 2 tension struts, they can make a special bush to fit in, after i take the old ones out i will search around for a replacement bushes for a experiment and the pins have been drilled out tim and i get pretty good negative camber with the M3 arms without camber plates
Also thinking of getting Bilstein shocks after sundays breaky run after tea and scones stop yummy heading back along some of the bumpy section my suspension was crashing not rebounding very good and not soaking up the bumps.
04-16-2012, 06:30 AM | #7 |
44
Rep 1,883
I'm interested to hear about replacement bushings for the struts/arms - if that's possible.
Yeah, pulling the pins out will you a fraction more camber. |
