04-08-2012, 03:52 PM | #2 |
Rep 1,379
Drives: Goal: Another ///M
Pad and rotors my friend. It sounds like you enjoyed your ///M.
14 Lexus GX460 & 14 Lexus ES300H 14 BMW 528d Touring Estate - UK Previous M's: 11 BMW M3 JZB ZCP 6MT, 02 BMW M3 Conv 6MT & 02 BMW M3 Coupe 6MT |
04-08-2012, 05:40 PM | #3 |
Rep 1,303
Read through searching that some people say the low speed squealing is normal and others said no, many said to bed the brake pads which I will try....just weird how this just started seemingly today
04-08-2012, 05:41 PM | #4 |
Rep 927
Squeaky doesn't mean worn. Sounds like you might be under using your brakes. Read up on bedding them....assuming you see that you have plenty of pad left.
Craig Brickner
Click to Join: BMWCCA # 366493 |
04-08-2012, 06:41 PM | #5 |
Rep 349
The brakes tend to glaze slightly if not used aggressively from time to time. This generally manifests itself with a squeaky sound particularly as you slowly come to a stop at say a stop sign or light. This is normal but can be a symptom of driving your high performance M3 like it was a Honda.
04-08-2012, 07:25 PM | #7 |
Rep 349
Keep in mind that this is not really a problem unless the squeaking bothers you. First, just make sure that your brake pads are not worn down (this shouldn't be the problem with only 17k easy miles.). Yes, bedding in the brakes should solve the problem...temporarily. If you continue to drive (brake) without aggression, the squeak will return.
04-09-2012, 09:24 PM | #8 |
Rep 196
I picked up a used M3 a few weeks ago and noticed the squeaking right away when breaking real soft at 5-10mph. Was getting a little embarrassed pulling into parking lots with people around. After a few hard stomps on the brakes at 40-50mph. Squeaking is no longer an issue
04-10-2012, 04:06 PM | #10 |
2395
Rep 5,849
