04-06-2012, 03:28 PM | #1 |
2304
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
Front Lower Control Arm Bushing OEM or Aftermarket?
Need to replace mine, has anyone gone with non-OEM (ie. Meyle, Powerflex, UUC, RE, etc)? If so any benefit or improvement over OEM? Was there any increased NVH?
Also curious as to when you had to replace yours. I'm near 50k and was surprised they already needed to be replaced. Last edited by 3002 tii; 04-06-2012 at 03:48 PM.. |
04-06-2012, 04:01 PM | #4 |
6 of Diamonds (ret)
82
Rep 566
Replaced mine with Meyle HD's in my E46 - huge improvement - but I was at the point of shudder everytime I braked. Couldnt help but be better. It probably also helped wear out the rag joint in my steering. I also just went on and replaced the lower a-arms and ball joints, $350 for the kit - good price to me.
http://www.ecstuning.com/BMW-E46-330...Kits/ES205226/ I'll probably do the same for the Z in a few more - I'm at 50K now but dont notice any lack of handling.
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
04-06-2012, 04:15 PM | #5 |
Rep 152
I'm at 60k miles and will be putting in the powerflex units in the next week or two. Waiting for my front lowering perches to get here before I rip the suspension apart to install everything (konis and lowering springs).
I went with the powerflexe lcab's hoping for a longer life span. I don't track the car and don't expect much handling improvement, I just like to upgrade every time I have to replace an OEM part. OEM parts usually are a compromise between price / quality. |
04-06-2012, 04:28 PM | #6 |
Bad Lieutenant
233
Rep 3,517
I haven't seen any aftermarket FCABs for the z4m, not even powerflex, but the non-M seems to have some available.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
04-06-2012, 04:38 PM | #7 | |
Certified Adrenaline Junkie
43
Rep 1,325
04-08-2012, 11:35 AM | #8 |
479
Rep 2,782
Drives: ESS/G-Power Z4M, VF Z4, 996tt
I bought some HD FCABs from Bavarian Autosport that already came in the brackets for $100 or so. The labor was EASY... just required a gear puller and some Dawn soap. I noticed a huge improvement as well, though I had 50k more miles than you but no track time. No noticeable changes in NVH, but again I just went with a harder rubber than OEM rather than track-oriented bushings. I'm very happy I did.
06-07-2012, 07:15 PM | #9 |
29
Rep 518
I need to replaced my arm bushing, I have a 2.5i what do you guys recommend me to buy, would this fit my car??
2005 z4 2.5i/// Aero front bumper, m rear bumper,08 rear lights, custom quad exhaust, matte black front grill, OEM alarm, llumar security film,m wheels, HID lights, LED interior and trunk light,Ipod integration, stubby antenna,tein s-tech springsx
06-07-2012, 07:30 PM | #10 |
enthusiast
48
Rep 1,695
With ANY after market bushing, you will get more NVH. For the control arm bushing, I would go aftermarket and since you track your car that would be my suggestion for you.
If you like the quiet, soft, comfortable no maintenance, go with stock. My BMW mechanic said that all the bushings are good for 50,000 miles. But what does he know? |
06-07-2012, 07:37 PM | #11 |
29
Rep 518
thanks guys, but I don't track my car, and my car now has 100k miles, dealer wants to charge me 600 to replace the arm bushings, I thinks is a good price knowing that just for the oem parts is close to 500, thats why I want to see what aftermarket parts you guys recommend.
06-07-2012, 08:40 PM | #12 |
enthusiast
48
Rep 1,695
I say this with experience. If you don't need more than stock, then I would purchase OEM. It will be stiffer just because its not worn out. My .02 cents
06-07-2012, 08:54 PM | #13 |
Dog Listener
707
Rep 7,850
06-07-2012, 09:09 PM | #14 | |
Rep 341
As mentioned above, a pretty easy DIY if you get bushings already installed in the carriers. Put car on stands, remove four bolts, use a big gear puller (or a hammer!) to remove the old ones. New one go on, as per above, with dish soap. Four bolts back in and you're done. Maybe need a new alignment if the old bushings were crappy the last time the car was aligned.
06-07-2012, 09:17 PM | #15 |
479
Rep 2,782
Get the Bavauto ones for $100. They come in the brackets and have minimal/negligible increases in NVH. You could do the job in under an hour (15 min your second time). Like spark plugs or coils, I would never pay a dealer to do it.
06-08-2012, 07:34 AM | #16 |
2304
Rep 12,570
I ended up going oem that were pre-pressed as well. Quick swap, no special tools needed. Only difficult part was figuring out how to take the existing one off the arm.
