ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      03-25-2012, 12:27 AM   #1
gcochard
Drives: 2011.5 E90 M3
2011 BMW M3  [0.00]
Valves adjusted at 27k
Just had my valves adjusted by Kaiv (Kevin). Great guy, super great rates. He brought all tools and shim kit, gave me a valve clearance checksheet, and checked my vanos bolts/hubs. He didn't mind me taking pictures as he worked either
5 valves needed adjusting, he reused two.
Inside the engine. Looks great:
RTV here, it was open before.
Vanos hub side 1:
Vanos hub side 2:
Shim screen. Apparently these weren't here on early motors:
Spec sheet provided by Kevin:
Spark plugs. Perfect color:
All buttoned back up:
      03-25-2012, 12:44 AM   #2
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Awesome...thanks for sharing. I've heard great things about Kevin and sounds like he's a specialist at this I will definitely be calling Kevin to do my adjustment as well later on this year (about 8k miles to go)!
Did you change out the plugs as well? Where did you get your transmission and diff fluids done?
      03-25-2012, 01:20 AM   #3
BMW Maniac
Drives: Former Z4M coupe owner
Shim "screen" what a novel concept!
1997 /// M3 Coupe Arctic Silver CES STAGE IV (651rwhp/615rwtq)
1999 /// M3 Convertible Techno Violet
      03-25-2012, 07:51 AM   #4
bignosejim
bignosejim's Avatar
Drives: 2007 IB M Coupe
Wow, that engine is super clean! Glad to hear no issues with the vanos. It was a big relief when I did mine, being able to see my tabs were intact.
Did you RTV the rear half moons? When I did my 07 MC, I didn't see any RTV around there so I didn't add any (unlike what the TIS says). So far I've had no leaks.
      03-25-2012, 12:24 PM   #5
gcochard
2011 BMW M3  [0.00]
No on the plugs, the interval is 60k so I'm sticking with that.
I got the diff and Trans fluids changed at 17k miles at bullet performance. They use redline, you can ask them to use OEM fluids. Since mine is under warranty, I just went with the redline since I didn't want to deal with getting oem at crevier. I think I will try oem next time (45k) and see if it feels any different.
Yes, he RTVd the half moons.
Interesting to note, all the shims that needed adjusting needed to be replaced with smaller shims. Does that mean the lifter or valve stem grows over time?
      03-25-2012, 11:04 PM   #6
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Valves stretch, and the valve seats can recede over time. I had 2 on the exhaust side tight like that as well.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
      03-26-2012, 10:53 AM   #7
gcochard
2011 BMW M3  [0.00]
Now that I think of it, we didn't RTV the half moons. Only the front seams.
      03-26-2012, 11:17 AM   #8
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
It is rare for leaks in the rear, pick up a small mirror and check is once in a while, if you feel or see oil (usually where the half moon transitions to the flat surface, it's a sharp area, then you'll know the rtv was needed. Was your gasket semi-oily when it arrived in the kit? I found my gasket pretty oily and cleaned it with dawn before putting it on the cleaned head surface.
      03-26-2012, 11:36 AM   #9
gcochard
2011 BMW M3  [0.00]
The gasket seemed very clean. He definitely did not clean it.
I'll be checking for leaks at the rear in maybe 1k miles...
      03-26-2012, 01:51 PM   #10
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
Glad to see your hub is okay. If I recall correctly TIS suggests to RTV the half moons.
Have you ever changed those cam bolts?
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      03-26-2012, 01:54 PM   #11
skim
Drives: 07 Z4MC
nicely done
Future mod consideration: exhaust, pulley
otherwise, very happy with how the m3 was born
      03-26-2012, 04:10 PM   #12
gcochard
2011 BMW M3  [0.00]
I have not changed the cam bolts, but I don't know if they are factory. They may have been changed some time before I bought it as the valve cover was off at some point prior to my valve adjustment, judging from the RTV already on the head. Kevin told me that there is none from the factory.
Anyway, I will most likely open the engine and do the cam gear test at some point between now and the next inspection. Maybe during the next oil change.
      03-26-2012, 05:23 PM   #13
runnerx
runnerx's Avatar
my buddy and I worked on his Z4M with roughly 20k miles never had the cover removed before (no valve adjust or vanos ever done to it) and it had the same RTV. His car came with the new cam bolts but with no loctite. We decided to replace them anyways + loctite to ensure they stay in place.
2009 BMW X5 4.8i
      03-26-2012, 05:23 PM   #14
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
There should have been, can be varying in color from blue, black or dark brown. I went with the clear 3M stuff though.
      03-26-2012, 06:05 PM   #15
gcochard
2011 BMW M3  [0.00]
I stand corrected.
I will keep an eye on the cam gear regardless. Maybe I'll just replace the bolts next time I am doing a valve adjustment.
      03-26-2012, 06:18 PM   #16
davesz4mc
Drives: 2007 z4mc
If your valves streached or wore enough seat of to require smaller shims at 27K you have bigger issues going on! You will not even need at shim at 100k at that rate. Post a close up of them spec shet and did you check any clearences yourself? A loose motor is not a happy motor.
      03-26-2012, 06:29 PM   #17
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
66
Drives: 2006 Z4MC Interlagos
Maybe I'm missing something; however, I was of the understanding that both inspecting and replacing the bolts required removal of the vanos unit itself? Not simply done while doing the valve work.
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM
      03-27-2012, 08:21 AM   #18
bignosejim
bignosejim's Avatar
When I did mine that way, I noticed a little oil accumulation after about a week of driving. Not enough to drip and it has been dry as a bone for the last couple of months.
      03-27-2012, 09:17 AM   #19
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
That is correct, When you take the valve cover off, you will not be able to see much less reach the whole cam bolts. They are behind the VANOS unit. I replaced mine and it took a few hours. Also requires specific S54 tools.
Here is a shot of the suspect bolts from when I did mine. Notice the missing VANOS and CAM Covers.
My replacement thread: http://www.zpost.com/forums/showthread.php?t=407826
Sorry not trying to thread jack
      03-27-2012, 11:28 AM   #20
gcochard
2011 BMW M3  [0.00]
I have the spec sheet. Here's the shims that were changed.
2.26 -> 2.24 (2.26 is not standard, but the micrometer measured it at that)
2.36 -> 2.32
2.32 -> 2.28
2.32 -> 2.28
2.36 -> 2.32
Yes, I verified all clearances before and after the shims were replaced. We did not document what shims were there for the valves that did not need to be adjusted...since they didn't need adjustment.
The shim sizes go from 2.60 down to 1.72 in .04 increments, I doubt I'll run out of sizes by 100k.
      03-27-2012, 11:29 AM   #21
gcochard
2011 BMW M3  [0.00]
I was simply saying I'll be pulling the vanos off next time I am in there.
      03-27-2012, 11:46 AM   #22
davesz4mc
Drives: 2007 z4mc
So a min spec shim would not fit into those valves? I find it hard to believe it would ever need a reduction in overall shim size. My car with 65k miles I put 6 bigger shims in and would of put another 10 bigger shims in if they came half stepped. I was after min spec on every valve.
It is an interferance motor so if you drove it to get the adjustment done they were a good spec right? I am confused I guess at what measurments you took to determine they needed to be reduced in size.
zpost
