      03-12-2012, 04:54 PM   #1
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Bmw 1m clutch upgrade
So in looking for a clutch upgrade i research all the clutches for the 08 n54 135i and ACT or HPF seem the best.
But in looking around for info on the 1m i thought since we have an n55 shifting linkage i have no clue if we have a n55 clutch or an n54 clutch.
In doing research i found out that the clutch disk in the 08' 135i differs from the clutch disk in the 11' 135i
- we have the same clutch disk as the 11' 135i which the part # ends in 8492
- our flywheel also differs from both the 08' and the 11' but from our flywheel to the 11' the flywheel differs from 1 single number in the part number.
Example
-11' - 3249
- 1m - 3250
Trying to find a clutch upgrade that works
Does anyone have any info on clutch upgrades for the 1m?!!!????!?
      03-12-2012, 05:05 PM   #2
robertm
Drives: 2020 M2 Comp
Didn't Turner recently buy a 1m? I'd call them. Or call some of the vendors you mention above and ask them?
Please let us know what you find out. I'm curious to know too!
BTW, you getting slippage?
      03-12-2012, 05:43 PM   #3
M///1rider
M///1rider's Avatar
Drives: 2011 BMW 1M
Umm when my clutch was i guess warmed up i did get a little slip when tested after going to the track.
I have 8000 miles.
But today when i tested it no slip so i guess maybe the clutch plate was really warm
      01-31-2013, 07:49 AM   #4
Alexey
Drives: M340
Somebody changed clutch (not OEM)?
      01-31-2013, 08:03 AM   #5
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
I think ZF Sachs makes an upgraded clutch.
http://www.sachsperformance.com/Sach...4376_4587.html
Here is ZF Sachs contact info...
S-Performance GmbH
Elbring 45
21217 Seevetal
Phone: +49-(0)40-3999 211-8
Fax: +49-(0)40-3999 211-9
Email: info@sachsperformance.com
I do not think Sachs has a US importer - yet.
Acording to RealOEM.com the 1M and the N55 135i's use the same clutch disc... # 21217598492
http://realoem.com/bmw/partxref.do?p...ur=&series=E82
      01-31-2013, 12:21 PM   #6
tchelo_rp
Drives: 1M Black - 11/12
I bought 2 months ago a clutchmaster FX300 for my 1M...and now it's handling better with the power...and the clutch pedal now it's a little lower and heavier, but the shifts are faster...
      01-31-2013, 01:09 PM   #7
Alexey
Drives: M340
S-Performance GmbH
Elbring 45
21217 Seevetal
I found this
http://www.performance-kupplung.de/s...mw/e82/1m.html
      01-31-2013, 01:28 PM   #8
MDORPHN
292
Drives: AW 1M
FWIW, I'll likely go with a SPEC Stg. 2+ clutch with a steel single mass flywheel (also made by SPEC) when my clutch is in need of replacement.
Believe it's available from Harold at HP Autowerks and from Jake/Dzenno at ProTuning Freaks.
Neil
      06-15-2013, 04:39 AM   #9
Shooto82
Drives: BMW 1m
I hv the same clutch slipping on my 1m with 18,000 km on it. Thinking of clutch master but not sure which of their ranges I should go for. With the tune iv done I makes 100nm extra. Also do I need to change the flywheels? Any recommendation
      06-15-2013, 08:41 AM   #10
CarJunkie
CarJunkie's Avatar
Drives: e82 1M, f87 M2cs
2020 M2cs  [0.00]
2011 BMW 1M  [0.00]
Flywheel change is not necessary.
Chutchmaster's website will tell you what kind of torque each setup can hold. Their clutches work really well. I used their street/strip clutch with heavy duty pressure plate in a prior car and it gave a noticeably firmer pedal, but was not hard to daily drive at all. I wasn't stuck in stop and go traffic very often, but when I was it got a bit tedious.
      06-16-2013, 05:11 AM   #11
Shooto82
Drives: BMW 1m
which will be a better choice, SPEC or Clutch Master for a daily drive car?? anyone tried both?
      06-18-2013, 06:13 PM   #12
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Clutchmasters FX300 and FX400 have been the two best sellers for our 1M customers.
      06-19-2013, 05:14 AM   #13
Shooto82
Drives: BMW 1m
I'm looking for the full kit with steel flywheels. Master clutch don't build steel flywheels only aluminum which causes lots of rattling sounds
      06-19-2013, 10:23 AM   #14
PerformanceRaceSolutions
Drives: BMW
We have done multiple Spec clutch installs at our facility on 335's and we recently just did one on an E92 M3. Every single customer has left happy. The best choice with a flywheel would be the Spec Stage3+ with steel flywheel.
      09-18-2013, 06:14 AM   #15
xavierbest
Belgium
Drives: 1M coupé/F81 330D/E93 320D
Originally Posted by Alexey View Post
For who want to read my feedback on the Sachs kit:
http://www.1addicts.com/forums/showthread.php?t=854391
I've done it with the CDV removal.
      09-18-2013, 08:06 AM   #16
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
There is good thread on e90post http://www.e90post.com/forums/showth...highlight=spec
After reading it all I think you will not go with single mass flywheel. For now best bet is SPEC stg2+ or 3+ with oem DMF. There was a few reports that ACT clutch held a good power though very short like for 10000-12000 miles
      09-26-2013, 06:17 AM   #17
RussianRoulette
RussianRoulette's Avatar
Russian Federation
Drives: 1M
I have a situation with my 1m. THe milage at this moment is 11k km.
Stock clutch had been changed on 6k km and I installed SACHS Perfmomance. Yesterday it began slip.
My specs - 400 hp and 600 nm.
What is better to install now? Should I change flywheel?
The usage is daily with some traffic jams and i don't care about heavy pedal.
On winter season I'm going to upload stock program.
any sugestions?
      09-26-2013, 07:27 AM   #18
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
Take SPEC stg2+ with oem dual mass flywheel for daily drive replace flywheel and when your gear box will be down vood to replace crankshaft rear seal.
any sugestions?
      09-26-2013, 05:30 PM   #19
HP Autosport
Drives: F80 M3
      09-29-2013, 10:10 AM   #20
jackkk
jackkk's Avatar
Russian Federation
73
Drives: M3 F80
Still hesitating and don't know what is better choice for a daily drive:
-Spec st.2+ and Steel Single Mass Flywheel
-Clutch Masters FX300 ans keep the stock Dual Mass Flywheel
Don't want to have any rattle noise.
      10-03-2013, 12:52 AM   #21
RussianRoulette
Russian Federation
Drives: 1M
what about CM FX350? any opinions?
I didn't find FX300 here http://clutchmasters.com/shop/?page=...11&ToYear=2012
I'm planning to order it and install with stock DMF for daily usage and track days.
      10-03-2013, 02:56 AM   #22
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
SPEC wheel will rattle for sure search on youtube... but you can go also with SPEC stg2+ oem DMF...
Anyway it is recommended to replace DMF with new one.
1addicts
