02-29-2012, 11:18 AM | #1 |
Rep 20
Strange feeling when going downhill
Hi
Just bought a z4m coupe. Question. When driving around 70 mph downhill, I let go of accelerator. There is like a weird noise. Sort of engine braking noise. Is that normal? |
02-29-2012, 11:26 AM | #2 |
Dog Listener
707
Rep 7,850
Can you post a sound clip? It's pretty hard to diagnose what a noise is without actually hearing it. If it's a decent hill, there's going to be some change in sound when you do that. What's "weird" or not depends on what it actually sounds like. IDK, someone else can try here, but I'd need to hear it.
02-29-2012, 12:26 PM | #7 |
461
Rep 4,531
This might be a stupid question, but is this your first manual car?
I've learned on a manual and been driving one the whole time I had my license (a big 5 years...whoooo). Anyways, manual cars (from my experience), don't coast well at all. Because you're always in gear, the car is naturally going to slow down and engine brake. The higher RPM you are in a gear, the more engine braking you will get. Automatic is completely different, because the car is taken out of gear and then the engine idles as you coast. In a manual, when the gas is completely out of the equation, not being used and you're driving in gear...the engine actually shuts off, and the gears keep the engine moving. That's where the engine braking comes from. If you go into first, go up to around 4k and let go of the gas, you will slow down dramatically, it's all engine braking. Correct me if I'm wrong, but that's the way I've learned it. |
02-29-2012, 12:43 PM | #10 |
461
Rep 4,531
Okay, it may just be the different compression ratios in the engines that you have owned.
My 2002 325xi never slowed down as much as this car does...but it was still present in my old car and never thought it was something wrong |
02-29-2012, 02:21 PM | #11 | |
Rep 146
Auto's engine brake as well, not as much as a manual does Auto's are still in gear as they slow down Engines do not shut off when coasting (manual or auto) |
02-29-2012, 02:42 PM | #12 | |
44
Rep 1,855
Now, it's Clarkson, so lots of things are wrong, but I always wondered how that logic worked, if at all.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust |
02-29-2012, 03:09 PM | #13 |
461
Rep 4,531
Well you're using less gas. I know on my E46 when you coast MPG needle goes to 0. When you kick in the clutch and throw it in neutral, you spike to 20 then level around 40 and stay there.
02-29-2012, 03:16 PM | #14 | |
Rep 784
Drives: 2011.5 E90 M3
02-29-2012, 03:25 PM | #15 |
Rep 784
Does it sound something like this?
4 seconds and 14 seconds... |
02-29-2012, 03:34 PM | #16 |
503
Rep 1,543
This might be a stupid question. What gear are you in at 70? One would assume at 6th, which is around 2800 rpm....
My V8 SUV is at 1500 rpm at 70 mph. These cars are a bit different. |
02-29-2012, 10:55 PM | #18 |
Rep 146
Would say somethings wrong with your gauge if it goes to zero, on mine it would swing to infinity and if i have the mpg on the display it would show 99+ mpg on coast.
02-29-2012, 11:12 PM | #19 |
461
Rep 4,531
Whoops, sorry. I haven't driven an E46 in awhile.
I was thinking 0, as infinity. The needle would swing far left, not right. Either way, injectors or something has to be shutting off to save fuel and affect the needle. If you were coasting and injectors were fighting, you wouldn't go to infinity. |
02-29-2012, 11:18 PM | #20 | |
Rep 146
03-01-2012, 01:13 PM | #21 |
44
Rep 1,855
I see now. I didn't know injectors shut off when coasting in gear. I always thought the engine was running, because I still heard the exhaust when coasting.
03-01-2012, 01:16 PM | #22 |
Rep 784
