01-24-2012, 07:58 PM | #1 |
108
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
EBC Sport Rotors / Cool Carbon Pads
This maybe should be in the Brakes / Suspension section; but since my intention is to improve my breaking at the track, I decided to put it here.
I've done one HPDE day with cool carbon pads and OEM Stock Rotors. Performance was surprisingly good. I wasn't going 100% though, cause I still had certain feelings that it'll over heat and fade, but could've just been paranoid. I ordered a set of EBC Sport Rotors, and will be trying out this combo on Feb 4th at PBIR (Palm Beach International Raceway). Will probably update this thread on how it goes, I just installed and bedded them in, so hoping for good results. Thanks for looking and I'll keep you posted for anyone that's interested.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
01-24-2012, 09:52 PM | #2 |
106
Rep 2,696
hey you're running the same thing I did for my last track day. If you're still running in the Novice group you should be fine with the setup and it's great on the street. however, once you get to the intermediate group and you really start picking up speed and braking you'll need to up to race spec pads. I'll go through a brand new set of CC's in a 2 day HPDE now Went through 3 sets of cc's and my stock pads last year.
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
01-24-2012, 09:58 PM | #3 | |
108
Rep 1,973
Doing hard 70 to 10 stops and 80 to 10MPH that is, stops.
01-25-2012, 10:31 AM | #4 |
106
Rep 2,696
If you got a yellow "BRAKE" light, from what we could tell it basically means you've been hitting the brakes very hard and there be fade. I get that light on all the time at the track haha. Rotors did fine with the heat, although on a hot day you'll still get a bit of fade from these pads once they really start getting hot. You'll probably get away with a track day out of them, but if your in the inters, def look at getting some race spec pads.
I just picked up a set of Hawk DT70's and DT60's for a pretty good price for this year. Also i'm going to be running the RB 2 piece rotors. If you're want to know where from PM me and i'll send you over to my friend. Also are you running the titanium shim backing plates? If not pick up a set before your next track day...highly recommended. PS...just noticed your sig picture...we both run white 135s and have the same number haha...i use 117 and 17
01-25-2012, 10:40 AM | #5 | |
108
Rep 1,973
Nice, those are actually my two numbers as well, 117 and backup of 17.. funny. I'm much lowered now than in that picture, also just put on some Vorshlag Camber Plates at 2.5 neg in the front... first time with those.. I'll hit you up about the RB Two piece, those are in my shopping list, but probably for after a screw these up a bit. Thanks again
02-06-2012, 01:41 PM | #6 |
108
Rep 1,973
So I ende up going with DTC-70 Front and DTC-60 Rear; man am I glad I did! Thanks Focusedintntions for the advice as well. These pads were amazing, allowed me to brake way later, the rotors did a pretty good job at dispensing heat, ~-150 degrees from previous track days.. could also be that most of the time, I got a full cool down lap, so take that number with a grain of salt.
02-06-2012, 01:54 PM | #7 |
106
Rep 2,696
Glad they worked out for you!! Did you bed them in at all before the event?
02-06-2012, 01:58 PM | #8 | |
108
Rep 1,973
8 stops from 70-10 from 65% to about 80% brake force 3 stops from 85 to 10 from 70% to 90% brake force Worked out great
02-06-2012, 02:00 PM | #9 |
106
Rep 2,696
By chance did you drive to the track with them in or pop them in and out at the track?
I'm asking b/c i'm debating popping mine in before i leave and swapping back when i get home....3.5 hour drive each way.
02-06-2012, 02:05 PM | #10 |
108
Rep 1,973
Mine was about 2hr drive, I drove with them on there and back.. put my streets back on yesterday.. no issues at all.
