01-17-2012, 04:46 AM | #1 |
Rep 22
bms downpipe fix v3
hello...
i'm new here and from switzerland. i tried finding some help in german forums for my problem but didn't get any.. i will try to explain: i ordered the bms dp fix v3 from burger tuning as i have optional akra downpipes installed.. i don't want to use jb4, cobb or any tune right now. i just want to remove the engine light that appears always.. after we installed the fix successfully we deleted the ecu from all errors and the engine light turned off. then i drove about 200miles until the engine light came back. my question: is anyone here using optional catless dp's and dp fix v3 together? if yes, which setting do i need to set on the dp fix so the engine light won't appear anymore? ps: i did not change the setting and let it at 6pm (general setting). hope you guys can help.. |
01-17-2012, 08:41 AM | #2 |
Rep 1,358
I recommend reposting your query here:
http://www.1addicts.com/forums/forumdisplay.php?f=229 There are a lot of regular 135 guys that have a lot of experience with this. Also you can always email Terry directly at Burger. Supposedly he's pretty prompt with assistance. Good luck, please let us know what you figure out! |
01-17-2012, 09:04 AM | #3 | |
Rep 234
01-18-2012, 12:37 AM | #5 |
Rep 22
yeah so that's the problem, terry always tells you to read the guide as it is everything posted there. but i am not able to open the ecu box all the time and change from setting to setting and try again..
i will try reading up on the other thread that has been opened. but it doesn't seems like that someone can help |
01-18-2012, 07:33 AM | #6 |
Rep 1,358
Did you read through the instructions? It tells you exactly what you need to do to fix errors. Open this up and go to pg 9:
http://burgertuning.com/instructions/BMSdownpipefix.pdf |
01-18-2012, 07:35 AM | #7 | |
Rep 234
