01-02-2012, 03:59 AM | #1 |
249
Rep 3,157
Hypercoil carbon springs?!
came cross this!
look interesting! I'm interested as usual lol http://hypercoils.com/PDF/Hyperco_Ca..._datasheet.pdf
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
01-02-2012, 11:25 AM | #2 |
1580
Rep 8,077
Drives: 11 E90 M3 Individual
One of the few CF parts that will ACTUALLY have some tangible performance benefit.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-02-2012, 12:18 PM | #3 |
141
Rep 5,264
Drives: 2008 E90M3
- Jason P
:Have: 08 E90M3, Varis VRS Front Lip, LS3, ESS Supercharger, Arqray Exhaust, Neez Wheels :Want: VRS Carbon GT Wing & Cooling Bonnet, LCI Taillights :Videos: EnvyRidesTV, GPR 1, GPR 2, GPR 3, ///MFEST |
01-02-2012, 04:28 PM | #4 |
249
Rep 3,157
who sells hyoercoil products on the forums?
01-02-2012, 07:53 PM | #5 |
1580
Rep 8,077
Vorshlag sells hypercoil springs with the AST coilovers...maybe they can get these for you.
01-02-2012, 08:00 PM | #7 | |
249
Rep 3,157
01-03-2012, 07:44 AM | #9 |
249
Rep 3,157
I'm really interested in the weight loss
01-03-2012, 12:44 PM | #11 |
78
Rep 684
Hi guys here's some information on the carbon-composite springs.
The beauty of this system, aside from the obvious weight savings and virtual elimination of side loads, is that it is designed to be tune-able and modular. You would simply purchase a set of 'spring elements', and put the appropriate number of elements in series to achieve your desired rates and deflection. For a race team which needs to constantly change the spring rates on a car, this system makes sense because you do not need to purchase ($$$) and carry a ton of springs. But if you are only looking for a single spring rate, this system may not make sense because an 800# spring would require 20X 16000# elements @ $75 each = $1500
01-03-2012, 04:31 PM | #12 |
249
Rep 3,157
so can you PM me a price?
01-03-2012, 04:59 PM | #13 |
159
Rep 1,624
When we last talked to them at PRI they still had these on test vehicles.
You have to think about other variables too such as debris getting stuck in a tight area on the spring. Would seem that when you pick up the little tire chunks on track that it would be a good place for them to get stuck. Also about bump stops with this set up, what happens when you bottom out the spring? We would love to try these out though. If your racing with them it would be a good idea to check legality |
01-03-2012, 07:22 PM | #14 | |
249
Rep 3,157
but I'm will to give it a try . it doesn't snow in Taiwan so i'll take the risk 30% lets weight on each corner is very tempting
01-03-2012, 08:15 PM | #16 | |
249
Rep 3,157
but very expenisve from what Richard told me just the spring it will cost $6000
01-03-2012, 11:50 PM | #17 |
78
Rep 684
^The way you would think about this system is that for a set of 20 elements (~$1500), you get a range stiffnesses by combining them differently, which is equivalent to having that many traditional coil springs. So if you divide $1500 by the 10 stiffness combinations, each spring equivalent would be $150, which is not too bad considering the weight savings, side load reduction, and life extension vs. titanium springs.
01-04-2012, 12:42 AM | #18 | |
249
Rep 3,157
can i just buy a setting per / wheels instead of the 10?
