11-22-2011, 02:49 PM | #1 |
"M"
25
Rep 159
Rd sport springs or kw sleeve-over kit?
Hey guys, I'm new to the forums, but I just wanted to know what you guys think I should buy. I'm debating between rd sport springs or the kw sleeve-over kit. I want to lower my car without ruining performance. Thanks.
11-22-2011, 03:57 PM | #2 |
136
Rep 3,293
I'm guessing funds aren't an issue. Go with the sleeve over kit, if your car has EDC then you get to keep that as opposed to getting a set of coilovers. Post pics of the car!
11-22-2011, 04:06 PM | #3 |
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
I haven't seen any reason to go with the KW over a set or springs. You can't go any lower with the sleeve kit.
11-22-2011, 04:53 PM | #4 |
e90post veteran
58
Rep 1,375
+1 I went with RD springs w/e36 bumpstops for that exact reason.. They have the drop I want at less than half the price of the sleeve over kit
2012 Melbourne Red/Bamboo Novillo E92 M3 - ZCP, ZPP, DCT, BMW Apps, Sat Radio, Heated Seats
Mods- 20" BBS LM DBK, 18" Volk TE37SL, iPE F1 Exhaust, OSS, Arkym, RD Sport, and much more... Thanks to- PYSpeed -- Morr Wheels -- OSS Designs -- iND-Distribution |
11-22-2011, 05:26 PM | #6 | |
8274
Rep 18,857
Drives: BMW
OP: Let me know if you have any questions on springs or KW Sleeve kits!
11-22-2011, 05:32 PM | #7 |
1890
Rep 5,508
The advantage of the sleeve over kit is to allow you to adjust the height - either lower than just lowering springs or higher as similar to the Dinan springs. Also makes it so you can corner weight the car for performance balance.
11-22-2011, 05:35 PM | #8 | |
432
Rep 4,650
KW S/O KIT Max Low F/R. RDS Springs. Last edited by Cal@Sonic MS; 11-22-2011 at 05:46 PM.. |
11-22-2011, 05:39 PM | #9 | |
e90post veteran
58
Rep 1,375
Also RD stance is perfect to me. Those tires on the rears are just too skinny and the offset isn't aggressive enough on those rear wheels.
Mods- 20" BBS LM DBK, 18" Volk TE37SL, iPE F1 Exhaust, OSS, Arkym, RD Sport, and much more... Thanks to- PYSpeed -- Morr Wheels -- OSS Designs -- iND-Distribution Last edited by MR///M3; 11-22-2011 at 08:33 PM.. |
11-22-2011, 05:42 PM | #10 |
17
Rep 423
Drives: E92 335i, 135i, E46 M3, 540i
Location: 1721 E. Lambert Rd. Unit C, 90631 La Habra, CA
I would personally go with the KW Sleeve over kit
11-22-2011, 06:36 PM | #12 |
"M"
25
Rep 159
Thanks guys for the responses. I haven't done much to the car but get 3M black tint to all sides. Just waiting for my matte black grills to come in the mail. Otherwise it is an 08' AW e90 m3 with edc, tech package, premium package, carbon fiber trim. Can't do too much to it yet since so many things are coming up in a few months. Wedding and looking for a house. Will post pics when I can. . Anyways, I think I might just go with the kw sleeve-over kit.
11-22-2011, 06:42 PM | #13 |
"M"
25
Rep 159
Btw. How easy is it to adjust the height of the kw when already in place? Can I do it myself without removing the tires? For instance, what if I'm not happy with the height currently and want to make it higher or lower than it is?
11-22-2011, 06:51 PM | #14 |
432
Rep 4,650
The front is relatively easy and can be done by simply jacking car up and taking the wheel off. The rear however requires a spring compressor and a professional is highly recommended.
11-22-2011, 07:41 PM | #15 |
307
Rep 13,093
Technically yes, maybe you can adjust the sleeve kit lower but if you check the recommended max lowering height that KW says their kit is meant for, it is no lower than a set of springs.
11-23-2011, 08:56 AM | #16 |
2382
Rep 5,837
I was considering the KW sleeve-over kit. However, after talking to a couple of vendors that sell this kit I decided against it because I was told unless you use the sport EDC setting the car is under-damped and the ride bouncy. I have no first hand experience but if that's true then it seems getting a sleeve-over to maintain EDC functionality is just not worth it.
Not sure if you'll run into the same issues with EDC damping and lowering springs or if it's the spring rate of the KW sleeve-over that's the problem? Again, no personal experience, just what I've been told... |
11-23-2011, 10:44 AM | #18 |
307
Rep 13,093
11-23-2011, 10:47 AM | #19 |
1277
Rep 17,493
Drives: like I'M BOUT THAT LIFE
umm cuz kw s/o is edc compatible n if he doesn't hav edc jus get rd
#datbimmerdoe #thatbimmertho
FOLLOW @datbimmerdoe on INSTAGRAM |
11-23-2011, 10:54 AM | #20 |
Rep 124
We have a customer that has the KW sleeve over kit with EDC and the ride is quite nice. We didn't do the install so I don't know exactly how it's adjusted... I believe Sonic installed it. The car is not slammed, but the stance is good. It's not bouncy at all. In my opinion it rides better than mine used to with Eibach sport springs.
11-23-2011, 10:56 AM | #21 |
307
Rep 13,093
11-23-2011, 11:00 AM | #22 |
1277
Rep 17,493
wut is there 2 explain? it's my opinion n if i was him thas how i'd look @ it...
