11-21-2011, 07:35 AM | #1 |
Rep 111
Need to have winter tires?
My car is my daily driver, currently have 19" wheels. I am debating whether to get a set of winter wheels and tires (dropping to 18").
The winters here are unpredictable - i.e. last year's snowmaggedon, but "freezing mix" is always a sure bet. I wouldn't drive unless I have to - as I would take metro and hoof it (live in urban space where I can walk to stores to run errands). |
11-21-2011, 07:57 AM | #2 |
44
Rep 443
I have winter's on my 19s. You don't have to down size the wheels. I work about 45 miles from home and have gotten caught a couple of times. The car is very good in the snow now with the Blizzaks. If you can avoid driving totally then I'd probably go that route and not get winters. The summer tires are frightening if you get caught in freezing precip even if it's a short drive.
11-21-2011, 08:16 AM | #3 |
1904
Rep 5,678
You should not drive on the summers in below freezing weather snow or no snow. Winter tires are a MUST HAVE if you are driving the car at all in winter. Summer tires are dangerous. There are examples on the forum here where people have thought they could get by without and ended up having accidents. If someone spends $60K or more on a sports oriented car, not spending $2,000 on a real winter set up doesn't make any sense at all IMO.
Whether you put winters on your 19s or buy 18s is personal preference. I ran a dedicated winter set up on 18s last year but this year put Blizzaks on the ZCP wheels. The 19s look better but they are less forgiving to pothole damage, etc.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
11-21-2011, 08:28 AM | #4 | |
1251
Rep 6,913
You might as well be driving around on cinder blocks in 30 degree temps....that's about the amount of traction you'll get with summer tires.
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
11-21-2011, 10:17 AM | #5 |
144
Rep 2,610
I put snows on when the temp goes below 40, and i don't even drive my car in the snow. It's for piece of mind, pot holes and worst case i get caught out there. If you plan to take your car out in the cold, it's worth it to have the snows. yeah you can get around in the dry no problem (take it easy) but is it worth it? Especially when it is cold..35* and rain, that's a bit scary.
11-21-2011, 11:10 AM | #6 |
Rep 380
i've been driving sports cars with summer performance tires for 11 years here in the dc-metro area and have never switched to winter tires for winter driving...i certainly never drive in actual snow or ice, *but as long as you're careful*, i don't see the temp issue being that big a deal...
it's actually strange to me how people can make a blanket statement like, "below x degrees, you're gonna be screwed with summer tires." is that ambient temp or road temp?...if the former, is that the high ambient temp for the day, or the low?...if the latter, how exactly do you measure that?
2020 X7 M50i on order!
11-21-2011, 11:36 AM | #7 |
314
Rep 8,496
if you dont' plan on driving in the snow, but need to get around in freezing temps, just get all-seasons, some types are cheaper than actual snow tires. I have Yokohama Advan S4s this year, and last year I drove in light snow with it, no issues. With the traction control on, the M3 is really tame and easy to handle in light snow.
11-21-2011, 11:37 AM | #8 | |
314
Rep 8,496
11-21-2011, 12:10 PM | #9 |
OIF Veteran
246
Rep 2,106
probably best to get a set of winters, better safe than sorry.
But, me being lazy, (and probably cheap) i've been through several winters (since 2007) in a M3 and now a M5 using their stock summer tires (19'' Contis) without issue. I just drive carefully, avoid driving in the snow when I can, etc. Not one incident....like a boss. hope my luck doesn't run out, *fingers crossed*
Retired: '06 BMW E46 ///M3
Current: '08 BMW E60 DINAN ///M5, Interlagos Blue, SMG DINAN Stage 2 Suspension, Exhaust, Stage III Software, Front strut braces, Intakes, 13% Underdrive pulley, 3.91 Differential, RPI Scoops. |
11-21-2011, 12:33 PM | #10 | |
1904
Rep 5,678
11-21-2011, 12:36 PM | #11 | |
1904
Rep 5,678
11-21-2011, 12:37 PM | #12 | |
1904
Rep 5,678
Or, I should say, that's what people who don't like the idea of winters will say
11-21-2011, 01:40 PM | #13 |
Rep 380
unless i'm missing something, this is the extent to which bmw addresses winter tires in the m3 owners manual;
"BMW recommends winter tires for use in cold winter driving conditions. Although all-season M+S tires provide better winter traction than summer tires, they generally fail to provide the same levels of cold-weather performance as winter tires." i'm not sure where the tire manufacturer states the precise temperature below which a particular tire should no longer be driven on, but for oem tires, wouldn't that information need to be provided with the car?...if it was such a hard and fast rule, it'd be pretty irresponsible for bmw not to reiterate it in the owners manual (not to mention the liability not doing so would create)... i'm not saying there's no value in winter tires -- i'm sure they're absolutely necessary in canada, and are a must anywhere if you're trying to drive in actual snow...but if you live in the dc-metro area, where the lowest average high temperature for any month is 43 degrees fahrenheit, and the average annual snowfall is 16 inches, saying winter tires are a must is totally misleading...
11-21-2011, 01:45 PM | #14 |
Rep 380
not to mention the fact that during dc winters, two or three day stretches of 50, 60, or even 70 degree weather are quite common...it'd be a shame to be handcuffed with winter tires on your m3 and not be able to have a little fun during those times...to me, that kinda defeats the whole purpose of owning a sports car...
11-21-2011, 02:32 PM | #15 | |
314
Rep 8,496
Generally, when you buy a car, the package given the to buyer includes the current tire brochure and warranty as the dealer is not on the hook with warranty issues on the tire. So If you got PS2s, then the dealer should have handed you the Michlein PS2 brochure on it which will state operating temps. That's what I got when I got my Evo 8 back in 2004, it came with OEM Yoko Advan summer tires, and I got a tire booklet stating the issue. Additionally, the car also came with a sticker on my door that said something to that effect of operating temps of summer tires.
Now, even if they didn't tell you, again, it's not a consipracy to sell winter tires to you, it's a risk and trade off each person will have to assess come winter time. I debated hard last winter to buy winter tires for the M3. When it came down to it, I assessed that personally, I don't want to get handcuffed and limit my driving when there's snow on the ground. As such, I made a purchase, and I'm glad I did. I had to leave early Jan morning to catch a train after we had that NE snow storm for a work function. I made it. Happy Motoring. Quote:
11-21-2011, 02:34 PM | #16 | |
OIF Veteran
246
Rep 2,106
---- Funny how this topic comes up every year. Wish people would use the search function more.
11-21-2011, 02:52 PM | #17 | |
1251
Rep 6,913
Well....You can lead a horse to water, but you can't make it drink!
11-21-2011, 02:58 PM | #18 | |
49
Rep 1,922
You will absolutely should see a message with the extreme summer tires, not being ideal and or dangerous in the cold and wet conditions. Coming from using tires like Azenis, AD048s and RE070s, I can tell you that things get dicey once the tires get cold. I do believe such a statement was coming with the RE070s on cars like the GT-R, probably even in Porsches with the Michelin Pilot series, can you imagine those tires in the winter... In this area we are a bit spoiled, once the roads warm up and the tires warm up, you really just need rubber to pavement contact to be ok, I've made it with summer tires too. Things go south fast when; there is a signficant drop in temprature, the tires are cold and or and there is very minimum rubber to pavement contact, roads not plowed yet, it's still snowing hard and fast. Another thing I will add, prolonged exposure to very cold tempratures to extreme summer tires will ruin them, you will start to see cracking and dryness after the winter season, the rubber compound is just not made to sustain such tempratures and it will take it's toll. Can you make it? Yes, will you be safe 100% of the time, probably not, total days you'll be 'at-risk' could be 3-4 tops (around DC). However, in the long run I think you will be best suited to invest in snow tires as they will both preserve your summer tires and provide a bit of confidence and safety to you, your passengers and those around you. ...Just my advice. |
11-21-2011, 04:02 PM | #19 |
314
Rep 8,496
^+1, yeah, I question whether an M3 actually needs snow tires in the mid-atlantic. I suggest just getting all-seasons if it's cheaper. If there's more than 1 inch of snow on the ground, and it's not plowed, given the ineptness of drivers in the area, I will not be venturing out, mostly not b/c of how I can handle my car, but how others cannot handle theirs.
11-21-2011, 05:12 PM | #20 | |
OIF Veteran
246
Rep 2,106
A lot of idiot drivers on the road in this area. Especially the ones that think they AWD or a SUV they can "take" the snow. I've seen so many wiped out on the side of the road.
11-21-2011, 08:39 PM | #21 | |
688
Rep 6,845
Drives: 2018 Audi RS5 coupe
I'll ask you this You're driving in say 30 degree weather, no snow, just cold weather, on your way to work. And the idiot in front of you brakes hard for no reason You slam on your brakes But since your summer performance tires don't have enough grip You brake in 70 feet, as opposed to the normal 55 feet Only problem is the other car was 60 feet away So you slam into the car in front of you All that, just to save $1.5K? Not sure if you're into gambling, but those look pretty bad odds You may be right, and it might be a conspiracy by the tire companies In which case, you've just saved 1500 dollars Or They were right, you saved yourself damage to your car, and no deductible And no hassle of seeing your car destroyed, through something you did
11-21-2011, 09:51 PM | #22 | |
2300
Rep 5,742
