11-10-2011, 09:05 PM | #1 |
88
Rep 1,105
stainless steel brake line install?
How much would someone charge to install a set of SS brake lines to oem brakes? Would any old brake shop due or is this a difficult job? Maybe dealer would do it?
11-10-2011, 09:47 PM | #2 |
33
Rep 429
Why dont you just ask someone who installs them and you'd have your answer?
Not to sound like a dick dude but a drive to a local brake shop wouldnt hurt you.. |
11-10-2011, 09:47 PM | #3 |
11818
Rep 23,187
My dealer did mine at the same time as a fluid flush for higher temp fluid. I provided the lines and fluid. Think it was 200 bucks.
11-10-2011, 10:23 PM | #4 |
collecting toys
41
Rep 810
It's a pretty simple DIY project, just got to bleed the brakes to get all the air out when you're done. Any shop could do it.
2011 e92 M3 Monte Carlo Blue ESS 535 - gone but not forgotten
2015 cayman GTS - new toy 2006 SLK 55 AMG sold |
11-10-2011, 10:26 PM | #5 |
88
Rep 1,105
90 percent of answers and questions on this forums can be found otherwise but that is the point of the forum to get info without seeking it out elsewhere. I also was wanting to know if the dealer would install non-oem brake lines.
11-10-2011, 10:36 PM | #6 |
11818
Rep 23,187
My dealer will install whatever you want just takes money. As someone above said it can be done yourself also but I didn't really want to mess with it.
11-10-2011, 10:53 PM | #7 | |
88
Rep 1,105
Cool the dealer is what I was hoping for. Is it worth the feel and change? |
11-11-2011, 08:32 AM | #8 |
9601
Rep 10,891
I'd say about 3 labor hours is a reasonable estimate for labor on the job. 1/2 hour per corner for the actual line install and one hour to bleed the brakes properly.
11-11-2011, 08:53 AM | #9 |
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Wow, that seems like an overly long estimate. 30mins to replace one line? One hour to bleed? That's crazy talk.
11-11-2011, 09:16 AM | #10 |
9601
Rep 10,891
The actual work can be performed much faster, of course, but the OP was looking for an estimate of what to expect when calling a shop. 3 hours with a full bleed is about going rate, from my experience.
11-11-2011, 09:21 AM | #11 |
11818
Rep 23,187
3 hours is actually what the dealer lists for that job. It shouldn't take that long but I also had the challenge kit which has 6 lines not 4 and they charged me for less than 2 hrs labor. I went to the track about a week after having it done and with heavy use I felt the pedal was firmer for sure and also more consistent feel throughout the day. Made it easier for me to modulate braking and get consistent results. More precise I would say. If you don't track I doubt you will notice it with street use.
11-11-2011, 07:56 PM | #12 |
928
Rep 15,818
My tech did mine in about 2 hours time
11-16-2011, 11:24 PM | #13 |
Supreme Allied Commander
3887
Rep 54,530
Drives: F80 M3
11-10-2012, 12:27 PM | #14 |
Rep 927
The rear mid lines are a PITA! You should invest in a long 11mm that can be bent like an "L".
Craig Brickner
Click to Join: BMWCCA # 366493 |
11-11-2012, 08:05 AM | #15 |
5275
Rep 10,672
I probably spent half my time on those rear inner lines. With the bleeding 3 hours seems reasonable to me. If you use a good independent shop that charges by the hour and has done the job a few times, they might do it in less.
I hate paying 2-3 times in labor what the parts cost. To me, the more DIY that I do, the more money I have for mods. I have not paid a shop in years for anything other than an alignment. |
