11-06-2011, 09:01 PM | #1 |
JtBlk M3
19
Rep 118
do i need new tires???
hey guys, i wanted to know your input on whats the best way to know if i need new rear tires. i have the 18inch stock micheline PS2 tires, and ~8K miles on the car. the tread is pretty low but obviously not bald or anything. maybe .5cm deep threads i would say. i know the weather is getting cooler as is the road surface, but iam getting alotttt more slip than ever for the last few weeks or month, how do i know if its time for new tires?? thanks in advance !
11-06-2011, 09:54 PM | #2 |
2435
Rep 5,902
Check to see if you have worn the tread down to the treadwear indicators (small raised rubber areas sitting between the tread blocks).
Also once the temp drops below 45F summer tires start to lose grip. Even if you don't get a lot of snow winter tires should be used if the temps stay below 45F. |
11-07-2011, 07:21 AM | #4 | |
2435
Rep 5,902
Also, it's not a bad idea to invest in a used set of OEM wheels and winter tires to play it safe in snow or cold conditions. |
11-07-2011, 09:22 AM | #5 |
M3Post Supporting Vendor
87
Rep 964
2/32" (the wear bars) is the legal minimum. Below 4/32", the wet traction will start to suffer noticeably.
If you do not have a tread depth gauge, here are some handy tests you can do with the spare change in your console: http://www.tirerack.com/tires/tirete...&affiliate=AW8
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
11-07-2011, 09:58 AM | #6 |
736
Rep 3,980
If my math serves me correctly, .5 cm is just under .25 of an inch or 8/32nds..sounds like to me you are at 6-7/32nds of an inch, well within spec.
Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
11-07-2011, 10:04 AM | #7 |
2435
Rep 5,902
11-07-2011, 02:10 PM | #8 |
736
Rep 3,980
Yea I did the conversion after I wrote it...still close enough. The OP is at around 6/32s still within the treadbar.
