04-07-2007, 07:40 AM | #1 |
Administrator
6737
Rep 4,201
Full BMW M3 Sedan and Coupe Press Release info including links to all the vital specs
Click here for Sedan Info
Click here for Coupe Info Click here to download the full press release as a Word Document (~64MB) Click here to download the White E92 M3 Catalogue including unbelieveable pics Here are some of the specs summarized: Length/width/height (unladen)) mm 4,615/1,817/1,418 Wheelbase mm 2,761 Track, front/rear mm 1,538/1,539 Turning circle m 11.7 Weight, unladen, to EU1 kg 1,655 Air drag Cd x A 0.684 Engine Config/No of cyls/valves V/8/4 Engine management MS S60 Capacity cc 3,999 Bore/stroke mm 92.0/75.2 Compression ratio : 1 12.0 : 1 Max output kW/hp 309/420 at rpm 8,300 Max torque Nm/lb-ft 400/295 at rpm 3,900 Suspension, front Aluminium two-joint spring strut axle with tiebar; small, positive compensation of transverse forces; reduction of brake dive Suspension, rear Five-arm axle with anti-squat and anti-dive Brakes, front Single-piston swing-calliper compound disc brakes. 360 x 30, vented and cross-drilled Brakes, rear Single-piston swing-calliper compound disc brakes. 350 x 24, vented and cross-drilled Driving stability systems ABS, ASC, CBC, DSC; variable M differential lock Steering Rack-and-pinion steering with hydraulic assistance and Servotronic Type of transmission SG 6 Tyres, front/rear 245/40 ZR18 / 265/40 ZR18 Rims, front/rear 8.5J x 18 EH2+ IS 29 aluminium, forged/9.5J x 18 EH2+ IS 23 aluminium, forged Power-to-weight ratio to DIN kg/kW 5.1 Output per litre kW/hp 77.3/105.1 Acceleration 0–100 km/h sec 4.8 |
04-07-2007, 07:44 AM | #2 |
478
Rep 3,044
Drives: 2011 Dakar Yellow M3, 2018 M5
one vital piece of information not yet disclosed : exact weight balancing.
did bmw finally achieve perfect 50/50?
[ESS VT2-625] [Akrapovic Evolution Exhaust] [KW Clubsports] [OSS Angel Eyes] [Revinora r-CRT Lip] [Vorsteiner Boot] [Challenge Race Diffuser] [See the Build Thread HERE] |
04-07-2007, 10:19 AM | #3 | |
Rep 179
04-07-2007, 04:10 PM | #4 |
478
Rep 3,044
i take that statement with a grain of salt, since bmw says that for almost all of their cars.
04-09-2007, 07:57 AM | #7 |
Rep 1
0-60?
Is anyone else surprised by the 0-60 time of 4.7 (shaving a tenth off the 0-100km time)?? The speculation in the mags has been all over the board from low 4's to "below 5", but I certainly expected a 4.5 or maybe a 4.6... I know I'm splitting hairs here but it's a stat worth splitting hairs over, IMHO.
Or is this a marketing ploy by BMW, whereas much like when the RS4 came out Audi posted 0-60 time of 4.8 but it has actually tested quicker than that. I can see BMW doing the same thing with the "dealer pamphlet" times but when the mags eventually get their hands on the car posting much faster times just to make us all drool even more... |
04-12-2007, 10:55 PM | #8 | |
Commander-In-Chief
2160
Rep 8,937
Drives: 2023 M2 Coupe, 2020 GLE 450
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
04-15-2007, 06:27 PM | #9 |
//Mdicted
347
Rep 9,988
Drives: a Cop Magnet
Garage List 2009 e92 M3 DCT CF ... [10.00]
2015 S-Works Roubaix [0.00] 2013 Trek Madone 5.9 [9.50] 2012 Scott - CR1-Pro [10.00] 2008 e92 M3 6MT (Up ... [10.00] 2002 e46 M3 Cabriol ... [7.00] 2006 e90-325i (DD) [7.00] 2002 e39 M5 (retired) [9.50] |
Procede that Vish!
i kid
04-19-2007, 01:08 PM | #12 | |
755
Rep 2,736
On second thought, maybe you'd be better off waiting until the M was parked. |
05-06-2007, 09:28 PM | #13 |
611
Rep 10,407
Full spec sheet
I know it was posted quite some time ago but doesn't this belong here (or perhaps even in its own sticky - mods?)? I kept losing the thread it was in and finally (obviously) just saved it on my hard drive. This is the definitive list with the most specs out there.
06-29-2007, 12:46 AM | #15 |
Rep 363
Acceleration
does anyone here think that the 0-60 time is a little conservative. I was ready to put my life on the M3 doing 0-60 in 4.3 secs.
06-29-2007, 03:22 AM | #16 |
611
Rep 10,407
Read up
This has been discussed ad infinitum on this board. BMW is oftern quite conservative in quoted times. Mags often get way better. Most think it'll do around 4.5 and maybe low 4's with M-DCT (if it launches properly...). In short I would not worry.
09-28-2007, 07:10 AM | #17 |
Rep 2
Here is test in France M3 vs RS4, somewhere around 2:45minutes of test there is 0-100km/h race! If Audi makes 4.8s then M3 is much faster, take a look at video!
http://rapidshare.com/files/57172312/E92M3_vs_RS4.rar |
03-19-2008, 07:08 PM | #18 | |
HUSTLER
14
Rep 1,317
E92 M3 ZCP- AW/FR w/Extended Leather) Packages: ZCP, 6MT, Fully Loaded E46 M3 - AW/IR 6 Spd, Fully Loaded. 19'' BBS LM DBK, V-CSL C/F Bmpr, Botld, Diff, V-CSL Custum IR-CF Center Counsel, V-GTR Hood, Dixis Ti 76mm, Meisterschaft Ti Sec. 1&2, EvoSport Headers, CAI, D/A Chip, tck d/a, Alcantera Headliner with Imola Red Sttitching.... Last edited by Jack28; 03-19-2008 at 07:27 PM.. |
