03-25-2011, 06:07 AM | #1 |
Rep 67
DSC Error message
Driving home tonight some warning lights came on, checked the manual and seems to be an error with DSC. Turned car off and on, still there and pressing the DSC button didn't clear the problem. I have to book in next week to have dash storage bin replaced so looks like something a bit more important to be fixed t the same time, anyone else had this happen?
Mark FC
2009 125i MSport Coupe, AW, auto, sunroof, 261's 2011 Landcruiser 200 Series GXL |
03-25-2011, 08:26 AM | #2 |
191
Rep 4,848
Had it on the 120D, and I know a few people have the same issue and it's usually the faulty optical sensor in the steering wheel. If you go to Coastline for service, ring up Jason and see what he thinks as they might be able to make sure there's parts before you get it in.
Just be careful - I think you might be in TIMYOYO mode. They are usually pretty good at letting you take it straight in with DSC error. Mind you they don't like you taking the car back until it's fixed.
Macan S Diesel - Carrera White
Macan Turbo - White 1///M - Valencia Orange |
03-25-2011, 05:21 PM | #3 | |
211
Rep 3,288
Drives: anything given a chance
03-25-2011, 05:51 PM | #4 |
European Editor
10607
Rep 22,992
OP - you might try this...
BMW steering wheel sensor re-setting… http://www.1addicts.com/forums/showthread.php?t=504482 Quote: Originally Posted by DriveHard HOPE YOU READ THIS BEFORE YOU G BACK.. sit in car, start engine, have steering wheel in straight ahead position without pausing, turn wheel slowly all the way to the left and pause at the end for a second or 2 withouth pasing, turn all the way to the right and pause at the end for a second or 2 repeat the last 2 steps and end in the straight ahead position. turn off car, wait a minute, restart, and drive away for a few hundred feet. you just calibrated your SZL ( steering wheel sensor to tell dsc if wheel is turned and to what degree) other lights come on by default. Good Luck... |
03-25-2011, 06:43 PM | #5 |
51
Rep 1,792
Sounds like a SZL failure mate. I had that a while ago.
The easiest way to be sure is if; DSC is completely off Turn Signal doesn't self cancel Hill-hold assist doesn't function Try what Dackel suggested with fingers crossed, otherwise it's a trip to the dealer. If you are in warranty, should be a breeze. If you're not ask for out of warranty assistance, because it's a very common fault and they do cover you - only if you ask! |
03-25-2011, 06:48 PM | #6 |
Rep 100
Had the same fault twice within 2 months- both times was the SZL (steering wheel angle sensor). In warranty so no charge, but otherwise would've been $2k each time, shit!
03-26-2011, 07:13 AM | #7 |
Rep 67
Thanks for the replies everyone.
Sparoz, I was going to ask what TIMYOYO stood for but I thought I would google first, all good now thanks. Mattyv, yep that's also my problem, the finish on the button thing is peeling off.
Mark FC
03-28-2011, 05:22 AM | #8 |
Rep 67
Took my car into Coastline this morning, they did the tests and have decided to replace a yaw sensor, happy with the outcome except for another trip to the dealer.
Got my dash storage bin replaced, seems to be a different (better) design now.
Mark FC
07-09-2012, 10:13 PM | #9 | |
Rep 71
Has anyone tried this? Did it resolve the issue?
03-15-2015, 09:43 AM | #10 | |
4338
Rep 6,196
Bringing this thread back to life because of a panic I had yesterday. Yesterday, I had to replace the right rear wheel bearing and hub. Car was in a very minor bump in the right rear, and the hub was slightly bent. Vibration above 130 and when braking at highway speeds. While I had the wheels off, decided to service the brake pads at all four corners. Pulled out pads, cleaned off the contact surfaces and applied a small amount of Brembo brake grease to the ends so the pads release easier. Put the entire right rear corner back together, wheel speed sensor back in and put the wheels on. Car was in the accessory position the whole time, and was turning the front suspension from kick to lock as I was servicing the brakes. Started car to move it to the alignment rack, and instantly got a DSC malfunction, tire pressure warning system malfunction, yellow brake failure warning and hill assist failure. WTF?!?!? I KNOW I put the bearing in the correct way, I KNOW I did not damage the sensor. Took everything apart and checked. Everything looks perfect. Perform alignment anyways. After alignment, all warning lights still on!!!!! Decided to road test on highway to get a better grasp of what is happening. As soon as I got on the highway, all lights cleared. GAH!!!! Apparently, while I was servicing the brakes, I had accidentally entered the steering wheel centering learning procedure. Just had to drive it to finish it. Learn something new every day. Thanks Dak for having this post so I could figure out WTF happened. Was worried I had fucked something up with the right rear wheel speed sensor. |
03-15-2015, 02:45 PM | #11 | |
European Editor
10607
Rep 22,992
Dackel
