01-24-2011, 02:20 PM | #1 |
FoxRed/Extended/CarbonLeather/CarbonRoof/Comp/Tech
14
Rep 100
Drives: 2011 AW M3 Coupe Dinan Exh 6sp
Location: Oregon Coast,02,330i,Mcoupe,03 Dinan S-2 M3 all sold
Rear foglight E92 M3
New here, anyone know where to get euro headlight switch with rear fog light button? If anyone has installed one,is it bright enough to use as back up light?
01-24-2011, 05:44 PM | #5 |
927
Rep 15,818
Would one from my 335i work?
or that old trick of making the button activated? basically wondering if the new LCIs have it..
01-24-2011, 06:38 PM | #6 |
Picking fights with sharks
Rep 133
The old trick of activating the button works just fine on the LCIs. Mine is a 2011.5 (October build) and I was able to just file down the "stoppers" on the light switch. Pretty easy to do, and saved me the $100 from not having to buy a new assembly.
01-24-2011, 07:32 PM | #7 |
927
Rep 15,818
Thanks
01-24-2011, 08:08 PM | #8 |
Car Guy
34
Rep 798
I moved the one from our 2007 335i to our 2008 M3 when we traded it in....works fine and its bright:
01-24-2011, 08:16 PM | #9 |
14
Rep 100
Can you guys tell me what you mean by the old trick of filing the stop buttons. Is that to turn the rear fogs on? Then are they on full time? The ones turner motorsports offer have the front fogs button too
01-24-2011, 08:27 PM | #10 |
14
Rep 100
The pictures are helpful, my switch has the silver on the knob I think the one in your pic looks better in plain black with the carbon leather trim. Where did you get switch?
01-24-2011, 10:04 PM | #11 | |
Rep 133
The switch Turner sells does have the front fogs as well, but hitting the switch would not do anything (as M3s don't have front fogs.) Here is a thread showing how to file down (or just break off) the plastic pieces that keep the switch disabled: http://www.e90post.com/forums/showth...light=rear+fog It took me like half an hour to do (just needs some patience), but it's super easy and you can't really mess it up. Edit: Now that I've actually looked at that thread, I see that it doesn't show you how to enable the button. When you take the lighting assembly out, it's perfectly safe to completely disassemble it. It's only like 3-4 pieces held together with loose plastic tabs. You can pry them open pretty easily. Once the switch is disassembled, you'll see that the bottom button (for the fogs) has three tabs that interfere with it being pushed in. Use a jewelers screwdriver or some small needle nose pliers to just snap those tabs off, and you'll be good to go. Last edited by Bosna; 01-24-2011 at 10:09 PM.. |
01-24-2011, 10:29 PM | #12 |
465
Rep 1,636
I did it myself for both cars and let me tell you it comes very handy for tailgaiters...
here are the links: http://www.e90post.com/forums/showthread.php?t=51749 http://www.e90post.com/forums/showthread.php?t=26545 http://www.e90post.com/forums/showthread.php?t=235851 |
01-24-2011, 10:33 PM | #13 |
14
Rep 100
Thanks I appreciate all the help,it sounds pretty easy and will save me some cash. I'll try it tomarrow
01-24-2011, 11:15 PM | #14 |
14
Rep 100
I checked out the links, thanks. I'm not sure but it sounds like I won't have to make the custom little white piece shown, because my car is new /2011. Is it the top or bottom button?
01-24-2011, 11:36 PM | #15 |
465
Rep 1,636
Bottom...incase you don't have the white piece here is a link to give you an idea of what you need
http://www.e90post.com/forums/showthread.php?t=95434 |
01-25-2011, 04:08 PM | #16 |
14
Rep 100
Rear fogs work, it only took about 15 minutes. My car had the plastic pieces, so no legos needed, button clicks on/off. Thanks for all the help the pictures made it to easy, just have to wait until it gets dark to see the full effect.
01-25-2011, 04:21 PM | #17 |
Rep 246
I know its probably a thumb question, but... how do get the switch out of the dashboard? i would like to try this mod. Its as easy as just breaking off some small tabs?
01-25-2011, 05:03 PM | #19 |
14
Rep 100
Yeah it's as easy as that if you have the little white plastic piece in the switch. Just use the links above the pics are very clear on what to do. The dash/vent piece pulls out with a little effort just work it out evenly. Then put your hand behind the switch and work it out. Then take it apart as shown in pics. Just be gentle on all the plastic tabs holding the switch housing and button in place. The button pushes out when the black tabs holding the white piece are released.
01-25-2011, 06:13 PM | #21 |
894
Rep 9,034
01-25-2011, 06:52 PM | #22 |
684
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
Hope this helps
I did this a while back. Took pictures and linked the DIY for the install.
http://www.m3post.com/forums/showthread.php?t=239098 You'll notice the orange rear fog indicator in the center display:
