01-11-2011, 03:09 PM | #1 |
Rep 660
NYC: Salt-coated roads
I'm guessing that this has probably been discussed 100x over already, but what risks, if any, are associated with driving your E9X on wintertime salt-coated roads?
Obviously, I'm primarily concerned with the spray effect; i.e. the coating of the undercarriage of the car (by the tires) with salt fragments. Is rust / corrosion a real concern here? I'm going to have the car hosed down at a luxury autospa in the near future - this will most likely wash away most, but not all, salt (esp. underneath the car). Invariably, residual salt will remain. Needless to say, a bit worried about it as the roads are literally white with salt. Last edited by Talk2meg00se; 01-12-2011 at 07:39 AM.. |
01-11-2011, 03:44 PM | #2 |
Rep 206
I wish we could sue the cities and counties for salting roads this much and any damage it causes to our property... why is it the east cost is the only place that does this? I mean the roads are literally white for months from salt not snow.
01-11-2011, 03:48 PM | #3 |
Rep 856
I feel bad driving on these salt covered roads. Especially for my wheels. After driving on salt i sometimes go to the self washing booths and spray the underside of the car with soap and water then slowly drive home.
///M3 Mods: | Eisenmann Race Exhaust | Primary Cats Delete (TTP) | ESS Tune | 19" Advan RS | Eibach Springs | MS Air Filter | BMW Perf. Spoiler | BMW Perf. Splitters | Euro LCI Tail lights | Angel iBright v.3.0 | 20% Tint | Matte black Kidney Grills | CF Side Gills | Painted Reflectors | Black M3 emblem
01-11-2011, 03:54 PM | #4 |
Rep 1,461
01-11-2011, 03:56 PM | #5 | |
OIF Veteran
246
Rep 2,106
cities can't predict the severity of snow despite forecasts and want to ensure roads can stay open for motorists, emergency vehicles, etc just wash your car or get a beater car
Retired: '06 BMW E46 ///M3
Current: '08 BMW E60 DINAN ///M5, Interlagos Blue, SMG DINAN Stage 2 Suspension, Exhaust, Stage III Software, Front strut braces, Intakes, 13% Underdrive pulley, 3.91 Differential, RPI Scoops. |
01-11-2011, 03:57 PM | #7 |
BTC maxi
222
Rep 1,124
01-11-2011, 04:02 PM | #8 |
Rep 856
Salt is not as bad as the sand mixed with small rocks they sometimes lay down.
01-11-2011, 04:25 PM | #9 |
Rep 255
In the last 20 years they have changed their thinking on how to deal with snow. The old thinking was to use plows to kep the snow under control. However, roads that became snow covered turned to ice and additional snow would not melt as fast. The new thinking is to never let the snow build up on the road. This means using lots of salt, especially on the higher volume roads like 84, 87, and 90. Its better this way but more car washing is required.
01-11-2011, 05:28 PM | #10 |
Rep 109
Yeah - we don't get a ton of snow in the Portland area, but out here they put down rocks/pebbles as 'salt is bad for the environment'. They dump it down and then it's there for the entire winter so you constantly have rocks flying up and chipping your bumper/hood and putting small cracks in your windshield. Pissed me off pretty badly when I first moved out here - you don't need a beater/4x4 in the winter here for the snow/ice, you need it so that your m3 doesn't get smashed up with all the rock pebbles.
01-11-2011, 05:43 PM | #11 |
Rep 177
Salt makes a mess of everything, rock salt will sandblast the paint as well if you drive over it before it dissolves.
We have had the most snow here in 15 years this winter and I think they dumped all 15 years worth of old salt on the raods to get rid of it. Luckily I have a couple other cars so its no big deal, but a lot of driving on the salt will start to corrode the aluminum suspension parts, heat shields, fasteners etc on these. Worst thing you can do is give it a salt bath and let it sit in the garage fir a while, condensation will keep the salt active for a long time. Best to drive it in a couple good rain storms to rinse all that crap out, a lot of newer 'no touch' car washes have the big jets that rinse of the bottom when you drive over them. I used to live in Chicago and used to watch 70s and 80s cars rust away in a few years, not to mention making it impossible to do any suspension work without a torch. Luckily most new cars have well plated fasteners and treated sheetmetal so no longer do they rot away in a couple years or rust to the point you cant disassemble chassis parts from rust. + 1 on the sand/gravel being the worse, they use it in the mountains here and after one or two snows it looks like someone shot the front of your car with a shotgun. Luckily I dont have to drive in the mountains when it snows. |
01-11-2011, 05:46 PM | #12 |
Rep 1,432
I think I'm in the same predicament as a lot of you guys. Is it worth spraying off the underside/sides of the car? I have a bit of salt/snow on the side of my car (not a lot, but it's noticeable). The problem is that the car wash is more than 3-4 miles from my place, so by the time I get back home, it'll probably be even WORSE than it was originally!
01-11-2011, 07:17 PM | #13 | |
1469
Rep 3,941
Glad I live in an area that never sees any of that white stuff. |
01-11-2011, 11:42 PM | #15 |
Rep 206
Mdyaman, I wouldnt sue a city for a icy sidewalk. Unlike most people I take responsibility for what I do, if I go out on a snow covered road it's my own risk. Hence me buying snow tires. The problem is most people driving are idiots when it comes to driving in bad weather around here... Maybe that's why they salt so much! I just wish they would be more conscious of the environment, the roads, and the cars driving on the layers of salt. It seriously only snowed maybe 1/4 of an inch here, yet they were out in full force salting . I mean any weatherman could have seen we weren't going to get hit (Washington dc). I was making a left turn coming home from work today and the cars driving by were kicking up enough salt that it was pelting the left side and front of my car... That's seriously to much salt. It's like rock salt too, not fine salt. They are all like nickel size pieces of rock bouncing around
To the rest of you north of here be safe though, your getting the worst of it. |
01-12-2011, 01:37 AM | #16 |
M-Flight Member
38
Rep 1,085
The car wash I go to has an underbody wash that is pretty good. I try to wash it at least once a week, which sometimes means being outside in freezing weather with a bucket of hot water. It is a PITA because the water freezes to the car, but it gives me peace of mind.
I don't think you have to worry too much though, there is pretty good plastic covering under the car, and steel isn't used too much, mostly aluminum. Besides, I think the car is warranted for 10 years for corrosion (I think it's 10 years)
2011 Le Mans Blue M3// Black extended Novillo w/ Blue Grey Aluminum trim/DCT/ZTP/ZCW/ZPP/ZCP Premium Sound ///Akrapovic Evolution Exhaust
2015 Audi S4 Prestige, Brilliant Black S-tronic 2012 Le Mans Blue 135i M Pkg DCT |
01-12-2011, 07:44 AM | #17 | |
95
Rep 2,528
Also, strangely in Nassau County, they havent laid down any sand this year at all. I always thought they avoided salt because of the well water and only used sand. Salt is better for our windshields.
"But resist we much; we must; and we will much; about that be committed." ~Rev. Al Sharpton 2010 E92 M3|Silverstone II|M-DCT|NCSW|2MT|ZCW|ZPP|ZTP|302|507|Gas Guzzler Tax |
01-23-2011, 02:29 PM | #18 |
Rep 660
Does anyone have a recommendation for car wash in the NYC area with a good undercarriage blaster / washer? The autospa that I took it to last week did a good job of cleaning the car generally, but they only gave marginal attention to the undercarriage of the car (despite my request).
Anyway, I'm looking for a wash that will really hose down the underside of car - with the fresh snow, yet another layer of (@#$@#$@#@!) salt has been dispersed. A wash with a legitimate undercarriage blaster is desired. Any recommendations appreciated; haven't been able to locate one via Google. |
01-23-2011, 02:57 PM | #19 |
Rep 1,430
Yeah the salt sucks but how many of you actually plan on keeping your car 10 plus years? Most of us only keep cars 2-5 years. You should be fine
e92///M3
TT Lamborghini Gallardo INSTAGRAM: CHRISTIANPERLES Lamborghini-Talk.com: Christian. |
01-23-2011, 03:19 PM | #20 |
Rep 1,211
For the Central Jersey folks, Showroom Hand Wash in Scotch Plains does a great job, and they'll do an underbody wash. They use the old conveyor and apply the detergent automatically, but they stop the line and hand wash the car with mitts, then start it again for the rinses and underbody. The underbody spray nozzles look like they get pretty good coverage. After going through a blower, they blow out the seams with air, then hand dry and do the windows. Lots of owners of premium cars use it and the results are great.
2017 X5 35d (Performance Center delivery March 2017)
2019 230i X-drive 2022 M3 base 2000 328i sedan (UUC suspension - still the favorite), 2006 M3 slick top - Alpine White/Cinnamon SOLD! 2008 E90 M3 SOLD! 1991 325iX (both great), 2019 Miata RF - various others not as memorable but gone. |
01-23-2011, 04:47 PM | #21 |
Rep 1,379
Drives: Goal: Another ///M
I plan to.
14 Lexus GX460 & 14 Lexus ES300H 14 BMW 528d Touring Estate - UK Previous M's: 11 BMW M3 JZB ZCP 6MT, 02 BMW M3 Conv 6MT & 02 BMW M3 Coupe 6MT |
01-23-2011, 05:06 PM | #22 |
87
Rep 3,384
a few days? even weeks worth of salt won't do anything harmful to the car. I rinsed mine a few days ago and I've learned to become a lot less anal. Just enjoy the car.
