      12-22-2010, 05:27 PM   #1
elitt13
elitt13's Avatar
France
156
Drives: 1///M Coupe & ///M2 CS DKG
2020 BMW M2 CS  [0.00]
2011 BMW 1M coupé  [10.00]
2007 335i  [0.00]
BMW Series 1M vishnu procede
sorry but i've not see anything on the forum
Do you think that the Vishnu proceed will work in the N54 modified by ///Motorsport??
Shiv if you read me thanks for the answers
- Série 1 ///M BSM -
      12-22-2010, 06:40 PM   #2
TunedM2C
TunedM2C's Avatar
829
Drives: 2016 LBB M2
Yes, as well as the JB4 but I'm sure they have to verify the N54 internals to be certain.
      12-22-2010, 07:41 PM   #3
Robert
417
Drives: 135i -> is350 -> Tesla M3 perf
Don't think tunes on existing N54 will work as is in 1M but that's not going to stop the tuners from modifying their software to be compatible with the new engine.
- There's nothing in my pocket other than knives and lint
      12-23-2010, 08:03 AM   #4
MDORPHN
292
Drives: AW 1M
Although there are increasing reports -- most recently on BimmerFile's podcast -- that "our" N54 will have improved cooling, tighter tolerances, and be better balanced, there has not yet been any suggestion that there have been programming or encryption-related changes to the ecu.
If this is the case --and you have the courage to risk warranty coverage -- then current tunes for the Z4is by, among others, JB4, PROcede, GIAC, CPe, and Dinan could be installed in the 1M.
Only time will tell!
Neil
      12-23-2010, 11:34 AM   #5
Fuerza
Drives: 2015 Taurus SHO
If it truly is the 335is, Z4is motor then why wouldn't the current tunes work?Until official BMW specs are released we all have to wait. Only thing I can think of is possibly a new DME that could interfere with what current tuners don't have access too yet. All in due time we will see 400 HP/TQ 1M's.
      09-29-2011, 08:11 AM   #6
elitt13
elitt13's Avatar
France
156
2007 335i  [0.00]
Up please, I've no answers about how to use my Vishnu Procede on my 1///M
Shiv please help me !!!
      09-29-2011, 08:55 AM   #7
Snertz
H O O N
Snertz's Avatar
Drives: ein M!
IIRC Shiv already has a tune available for the Proceed specific to the 1M, as does Terry on the JB4. PM him on the E90post forums or email, I don't think he comes on 1Addicts too often.
U WOT M8?
      09-29-2011, 10:37 AM   #8
MusclezMarinara
Drives: VALNCYA
i have one up for sale with the 1m maps and 2.5 board if your interested
      09-29-2011, 10:58 AM   #9
Gtrain
Taiwan
144
Drives: something slowwwww
Both vendors have mentioned it would work. There were some posts about the JB4 not being that smooth. As for the Procede I have not seen any posts on it being installed on a 1M yet.
      09-29-2011, 10:59 AM   #10
Gtrain
Taiwan
144
Did you get to install and try it? How did it go?
      09-29-2011, 11:19 AM   #11
elitt13
elitt13's Avatar
France
156
2007 335i  [0.00]
thanks, but I have already one
I must download the good version of the soft for the 1///M
How do the 1///M button worked with your procede!!you don't used it on yours 1///M wright!!
I've send a PM to shiv on E90post but I haven't a response ...
this thread was create on E90post for that reason but it fly here!!!
Certainly a Gulf Stream's problem
      09-29-2011, 11:30 AM   #12
elitt13
elitt13's Avatar
France
156
2007 335i  [0.00]
oups sorry
I found the post on the E90forum
http://www.e90post.com/forums/showth...6#post10515506
I'm waiting for a response !!!
      10-30-2011, 04:07 PM   #13
M3EST
Rear wheel drive fanatic
M3EST's Avatar
53
Drives: M3 E30-1M-M4
1987 BMW M3  [0.00]
2011 BMW 1M  [10.00]
Still no news about 1M prcede map?
      11-02-2011, 04:23 AM   #14
elitt13
elitt13's Avatar
France
156
2007 335i  [0.00]
no, no news either!!
I send an other mail to shiv for an answer, I don't know why i don't have any responses???
      11-02-2011, 05:02 AM   #15
M3EST
M3EST's Avatar
53
1987 BMW M3  [0.00]
2011 BMW 1M  [10.00]
Probably he hasn't done anything.
      11-02-2011, 08:47 AM   #16
MusclezMarinara
Drives: VALNCYA
I HAVE MY PROCEDE FOR SALE
ASKING $700.00!
NEW NEW NEW
sent into shiv with updated 1M maps ! Im not using it if anyone wants to buy it its VIN UNLOCKED
SPECS
N54 PNP 1M MAPS LOADED!
NEW NOT VIN LOCKED
[/B][/COLOR]
If you want it all, right now, this is the PROcede to get. Custom tunable (through qualified tuner) and with all map activations enabled. For use on 2007-2010 model years. As well as the 2011 335IS, and Limited Production BMW 1 M COUPE NOT for use on the 2011 and up 135, 335, 535, etc,.
$945 PROcede Rev2 V2.5 Includes MSRP!
- Includes USB Comms cord
- User manual
- Harness
PRO VERSION!
- Plug and Play (PnP) Harness
- AutoTuning
- Vishnu Command Center
- Closed-Loop Ignition Timing Control
- Flat-Foot Shift/No-Lift Shift (6MT)
- 2-Step Rev Limit/Launch Control (6MT)
- Built-in PWM Methanol Control I/O
- Built-in Methanol Pump Arming Circuit
- 3bar MAP sensor input
- External 0-5v wideband input
- Automatic Wastegate Compensation
- In-Dash Multi-Informational Displays
- On-the-fly Mapswitching
- DME code reading/clearing
- Built-in Wideband AFR Monitoring
- High-Speed Datalogging
- In-Dash Trouble Code Display
- Isolated PID Boost Control
- Speed Delimiter
- Diagnostic Invisibility
- Adjustable/Audible Shift Alert
- Diagnostic Adaptation Resets
- Wastegate Rattle Fix
- Performance Traction Control
- Secondary Autotuning Map (Map2)
- Naturally Aspirated Map (Map3)
- Progressive Methanol Map (Map4)
- Complete map-ability though User Tuning Interface
      11-07-2011, 09:07 AM   #17
elitt13
elitt13's Avatar
France
156
2007 335i  [0.00]
I have a shiw answer
Hi Eric,
-- The standard Procede maps will work perfectly on your 1M. No special file needed Please let me know if you have any other questions.
--The M button will work in all Procede maps. They are two different systems and don't --cross talk with each other. And yes, 6MT launch control/2-step is available for 1Ms as well
Cheers
shiv
!!!YES It's good !
1addicts
