02-06-2007, 11:25 AM | #1 |
Rep 1,181
Drives: G29 Z4 M40i Roadster
Carbon Fibre Z4 Coupe and Z4 roadster from TC Kline Racing
What do you think: Fully Carbon Fibre Z4 Coupe
TC Kline Carbon Coupe Specifications: Body TC Kline Carbon Fiber Composite skin over steel unibody Dimensions Length 161.5" Width 72.1" Height 50.2" Wheel Base 98.3" Track Front 60.2" Rear 61.4" Weight 2,740 lbs (unladen w/out A/C or Radio) 2,790 lbs (W/ A/C and Radio) Interior Recaro/TC Kline Custom light weight one piece shell seat w/ Leather upholstery Optional – Recaro Sport Seats or Recaro Racer SPG Racing Seats Engine BMW 3.2 L inline Double overhead cam 6 Cylinder w/Iron Block and Aluminum Head 342 hp @ 7900 rpm 262 lb/ft torque at @4900 rpm Exhaust TC Kline Thin Wall Stainless Flywheel TC Kline 11.2 lbs Aluminum Transmission BMW 6 Speed Manual Gear Ratios 1)4.35 2)2.50 3)1.67 4)1.23 5)1.00 6)0.85 Differential BMW M Lock Limited Slip Final Drive Ratio 3.62 Suspension Front TC Kline/KONI Dbl Adj Struts TC Kline light weight 60mm ID Coil Over Springs TC Kline Adjustable Camber Plates TC Kline Delrin Lower arm Bushings Rear Multi-Link Trailing Arm TC Kline Dbl Adj Shocks TC Kline Light Weight Coil Springs w/Adjustable Spring Lands TC Kline Delrin Trailing Arm Bushings (Spherical Ball Joint Bushings and Rear Lower Arms or BMW Rubber Optional) Brakes Front Performance Friction 4 piston MonoBloc Aluminum Calipers 345mm Floating rotor w/aluminum hats Rear Performance Friction 2 Piston MonoBloc Aluminum Calipers 321mm Floating rotor w/aluminum hats PFC Carbon Metallic brake pads Wheels and Tires Light Weight One Piece Forged Aluminum w/Michelin PS2 or Pilot Sport Cup Tires Front – 18x9.5" wheel with 265/30x18" tire Rear - 18x10.5" wheel with 295/25x18" tire Optional 19x9.5 front and 19x10.5 rear Forged Aluminum 18x10 front and 18x11 rear Forged Magnesium |
02-06-2007, 11:25 AM | #2 |
Rep 1,181
The roadster:
More info on the roadster and coupe under: http://www.tcklineracing.com/coupe.htm http://www.tcklineracing.com/roadster.htm |
02-06-2007, 12:12 PM | #3 |
Administrator
40865
Rep 21,240
Yup definitely one of the hottest Z4 roadsters out there... costs a pretty penny or two also
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
02-07-2007, 03:01 PM | #6 | |
Rep 1,181
TC Kline Z4M Coupe: 2,740 lbs Standard Z4Mcoupe: 3,230 lbs Do your math, and the difference is: 490 lbs. |
02-07-2007, 05:43 PM | #8 |
1569
Rep 29,202
The TC Kline Z4M Coupe is the cover car in BMW Car this month.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
03-11-2007, 05:06 PM | #10 |
29
Rep 2,134
Make that two....
2007 E92 335i Coupe: Monaco Blue/Premium/Sports/Winter Package/Nav/CA/6MT/TT/Active Cruise/Active Steering/iPod/Rear Shade/Tint/Short Shifter/OEM Alum Pedals//
03-31-2007, 11:25 AM | #11 |
Rep 336
Inkidoo
|| 335i Sedan || Montego Blue || Black Leather || Aluminum Trim || Sport Package || STEPTRONIC || Paddle Shifters || BWM Assist/Bluetooth || Park Distance Control || Comfort Access || Navigation System || Satellite Radio || |
04-01-2007, 07:25 AM | #12 |
218
Rep 3,592
I would love to do a back to back comparo on the regular mcoupe & this one just to see the difference & hopefully be really wowed by it...I would just paint it to something else not orange (read Stealth) :-D
'08 E92 M3 6MT | IB | FR | RAC RG63's | VRS Ti Exhaust | Fabspeed HFC & Xpipe '09 X5 35d SG/SB '11 X3 28i AW/CN/FW (wife's car |
08-12-2016, 10:43 AM | #13 |
dances with roads
4732
Rep 4,096
Dredging up from the dead. I saw the Carbon Coupe in the flesh on Tuesday. It's on loan to the BMWCCA Foundation in Spartanburg SC. It's gorgeous! And the hood weighs, like, two feathers. Lots of other cool stuff to see there by the way.
08-12-2016, 03:19 PM | #15 |
423
Rep 5,328
i wish i could get those fenders!!! wow!!!
roadster looks so much better to my eyes!!
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
