08-03-2010, 09:36 PM | #1 |
Rep 640
DIY Stub Antenna
A quick snip of the stock antenna and voila BMW Stub. Ten minutes $0. If you don't care about AM/FM. I don't - prefer to listen to Sat, IPOD or exhaust.
1. Unscrew antenna from vehicle, I guess you could do this in place if your careful. 2. Slip off the rubber snubber on the end of the antenna using a pair of diagonal cutter or other suitable tool. It is not glued on. 3. Snip the antenna 0.5 -0.63 from the base, using a good pair of diagonal cutters or other cutting device. Cut it just below where the diameter increase due to the wire wrap. 4. Gentley squeeze the remaing end to reround. 5. Lightly lubricate the ID of the rubber snubber with saliva and slip it onto the stubby end. 6. Reinstall on vehicle.
HerrK - 2021 X5 40i M Sport l PCD l Atlantis Blue/Ext'd Tartufo Merino l M Sport w/blue Calipers l Matt Popular l HK Sound l 740's l Exec & Drive Pro Pack Sold w/Great Memories - E89 Z4 l ED 2010 l 2011 35i l Crimson/Ext'd Coral Red w/Alum l 6 sp MT l Prem Sound l Sport Pack l 296's |
08-03-2010, 11:36 PM | #2 |
Rep 154
I still prefer the citroen/peugeot one that has been discussed and shown previously. It is a lot shorter and cleaner.
is your reception affected in any way? Good effort nonetheless !! |
08-04-2010, 08:24 AM | #4 |
62
Rep 2,087
But it's shorter now
"Political correctness is a doctrine fostered by a delusional liberal minority and rabidly promoted by an unscrupulous mainstream media which holds forth the proposition that it is entirely possible to pick up a turd by the clean end".-- Unknown
08-04-2010, 08:37 AM | #5 |
Rep 131
For £7.00 think I'd rather have the shorter one
35iS, Deep Sea Blue, 19" 326 alloys, etc
08-04-2010, 09:07 AM | #6 |
Rep 140
or $9.99 US
http://www.mangowalk.com/index.php?sku=30174 BTW Bill, looks like that DSB needs a bath.... |
08-04-2010, 10:38 AM | #8 | |
Rep 131
Yes it does
08-04-2010, 11:52 AM | #10 |
93
Rep 1,838
the aerial antenna is for AM and it's the cars cellphone extension if you connect thru the armrest base. so you'll lose AM, and the "extension" of cellphone reception.
Personally I've never missed it.
08-04-2010, 08:59 PM | #11 | |
Rep 640
Well despite the surgery on the stock "antenna", I still have both AM & FM, good reception at least here in San Diego - damn the bad luck. Can't speak to any "built in cellphone reception" issue - I personally don't need to be that connected.
08-05-2010, 04:57 AM | #13 |
Rep 131
No problem whatsoever same as the standard one, but I think it depends on the area you live in.
08-05-2010, 04:57 PM | #14 |
Criminally Insane
53
Rep 1,464
Drives: Like a Demon!
The good news is, they are cheap, and interchangeable.
IF you get one and dont like what it does to your mobile phone reception (or heaven forbid you actually listen to AM radio), you can always swap back. Unless you do the Brit Milah process described above by HerrK.
Dr Stig 2010 Z4 35is 2011 X3 30d M Sport Australia |
08-05-2010, 05:48 PM | #16 |
Rep 446
Drives: '09 Z4 s35i & '03 Z4 3.0i
I didn't know it had an imact on the cellphone reception but I just use Bluetooth not the cradle so no issues.
I got the Pugeot antenna, AND, I still have the OEM antenna in the trunk if I need it (like I'm going to start listening to AM anytime soon ) The mangowalk ones have a slightly different angle on the base and don't fit perfectly if I remember correctly. If they fit an E46 (and they do) then they aren't correct for the E89. close but not "right".
Member ZSCCA 2009 Z4 s35i with Dinan Stage II software, Sport and Exec packages, 19" 296 rims , a stubby and mud flaps
'03 Z4 3.0i Sterling Grey (Hers) '01 Z3 3.0i Sapphire Black, M sport package (Mine) |
08-05-2010, 09:15 PM | #17 |
Rep 140
From the pics I've seen, it looks to be a perfect fit, but I will find out for sure on Saturday - I take delivery of my Zed4 (I already have the Mangowalk)
08-05-2010, 09:37 PM | #18 | |
Criminally Insane
53
Rep 1,464
Time dilation is a bitch.
08-05-2010, 09:40 PM | #19 |
Rep 140
08-05-2010, 09:43 PM | #20 |
Criminally Insane
53
Rep 1,464
Do you want me to send you a HTTP script that will do a count down for you in your signature?
see http://www.dynamicdrive.com/dynamici...dhtmlcount.htm
08-05-2010, 09:47 PM | #21 | |
Rep 640
The all knowing Dr. I did indeed perform this ceremony on the eighth day after redlivery.
08-05-2010, 11:00 PM | #22 | |
Criminally Insane
53
Rep 1,464
Mazal tov!
