06-06-2010, 08:07 PM | #1 |
Member at Large. Probably Driving Aimlessly
14
Rep 170
Drives: 2010 X5 M PKG & 2010 650 VERT
Sounds like Water Hitting a Hot Pan
Hi All,
I was wondering if anyone else experienced this... I am hearing a sound in the engine compartment that sounds like the title. I have been running the A/C so i am thinking it is the liquid condensation. there havent been any fluid puddles in the garage or elsewhere and i do not see anything from the top or bottom. Has anyone else hear this noise? |
06-06-2010, 08:14 PM | #2 |
168
Rep 2,736
Drives: 2008 E92 ///M3 Alpine White
Yea, as far as I know it's normal...had it on my 545i and my ///M...
06-06-2010, 08:15 PM | #3 |
14
Rep 170
Thanks Krozi
06-06-2010, 08:46 PM | #5 |
258
Rep 5,012
Yes. Noticed this right away too. Forgot to snoop around when I had the belly pan off to bleed my clutch. There must be a hose somewhere that we can reposition, or add an extension. Hope I remember next time.
You can say that again. This is my first car to do this (and I've had many RWD cars before), and it's definitely not a compliment . Last edited by JCtx; 06-06-2010 at 10:59 PM.. |
06-06-2010, 08:58 PM | #6 |
I like cars
331
Rep 5,052
AC condensation. If it's sizzling it's hitting the headers, if it's not sizzling it's hitting the metal tray beneath them.
I can't think of a car I've owned with a front engine V8 that hasn't done it. My E46 M3s also did it. |
06-06-2010, 09:53 PM | #8 |
86
Rep 2,148
It's the condensation buildup when you use the AC. The droplets fall and hit the hot pipes making the sizzling sound. You'll notice it more during the hotter weather.
06-06-2010, 10:02 PM | #9 |
Ultimate Driver for the Ultimate Driving Machine
146
Rep 1,146
Had the same issue, took the car to the dealer, they said it was ok
BMW M3 E92 - Silverstone II BPM Sport Stage II Tune + Test Pipes, GTS DCT Tune |
06-07-2010, 10:14 AM | #11 |
403
Rep 3,288
I have a new 2011. Same issue. I figured it was just he car cooling the moment I heard it. Especially if you live somewhere hotter than usual. Or more humid.
06-07-2010, 07:50 PM | #13 |
258
Rep 5,012
If it drips on an O2 sensor or any other bolt/nut, try to remove that sucker in a couple of years and you'd change your mind . There's no reason why a proper drain hose was not installed if dripping was going to happen on exhaust components.
