12-18-2009, 08:18 AM | #1 |
Freude am Fahren
339
Rep 5,254
Interesting History of BMW's Roadsters and Z4
BMW introduced its first roadster, the 315/1, in 1934 at the Berlin Motor Show. The 315 featured a long engine compartment, a six-cylinder motor, two sports seats, and a speedometer that went up to 150 km/h. The result? Instant Freude am Fahren (Joy of Driving, BMW’s tagline).
Feature continues here
Freude am Fahren.
Jonathan E90 2006 330xi E90 2006 325i E39 2003 530i Sport* E46 2000 328Ci* E36 1996 328iS* E36 1992 325i* E30 1991 318is E21 1982 320iS* E21 1979 320 (6-Zyl)* *retired Nominated: Most Contributing Member |
12-18-2009, 08:25 AM | #2 |
93
Rep 1,838
i like this:
"The 2008 Z4M Coupe (M indicates BMW’s performance division) started at $50,400; the 2009 Z4 sDrive35i starts at $52,475, with no M badge, still drives like an M car and has the advantages of being better looking and more fuel efficient to boot."
12-19-2009, 01:15 PM | #4 |
Rep 27
If you like to know more about 315/1 (1935)
Front suspension was made up of the upper track spring, wishbones further down and hydraulic lever-type dampers. The rear wheels, in turn, were mounted on a live axle incorporating semi-elliptic springs and hydraulic lever-type dampers.
Small but hot: six-cylinder power unit displacing 1.2 litres. Both the saloon and the sports car were powered by the same outstanding engine: a 1.5-litre straight-six developed out of the 1.2-litre originally featured in the former BMW 303. The crankcase and cylinder block of this outstanding engine were made of one single piece, the engine featured one camshaft beneath the block, with tappets operating the vertical hanging valves aligned in series via rocker arms. The intake and exhaust pipes, finally, were on the same side. A feature quite unusual today is the different distances between the individual cylinders, with the second and third and, respectively, the fourth and fifth cylinders being further apart, the space in between being used for the crankshaft and amshaft bearings. The crankshaft without any counterweights therefore ran in four bearings, just like the camshaft. This was however not the reason for this particular design and configuration, which was rather attributable to the assembly process at the time, with the crankshaft being completely pre-assembled together with the connecting rods and pistons. And since the pistons, as a result, had to be inserted from beneath, the main bearings for the crankshaft had to remain outside of the cylinders, not extending into their contour lines. As a result, the main bearings had to be accommodated between cylinders spaced out at a large distance. While this power unit delivered maximum output of 34 hp on the saloon with its two carburettors, maximum output of the six-cylinder in the BMW 315/1 sports model was 40 hp. And the standard of efficiency offered was quite exceptional, BMW's engineers proudly stating that "this beautiful and fast sports car consumes only 10-2 litres of fuel on 100 km, with oil consumption between 0.1 and 0.2 kg. So in terms of running costs, it is no more expensive than a small car far lower down in the market". With the public simply falling in love with the BMW 315/1, BMW decided to build the car in a small series - also because the Company wanted to make a more powerful entry into the prestigious world of motorsport. Starting in summer 1934, therefore, the very attractive BMW 315/1 was retailed at a substantial 5,200.- reichsmarks. The production model differed from the prototype primarily through the modified arrangement of the headlights and side ventilation grids taking the place of the bent openings originally featured on the first model. Outstanding success in motorsport. Reaching a top speed of 120 km/h or 75 mph, the BMW 315/1 Roadster was one of the really serious contenders in the sports car market at its time. Indeed, BMW's story of success on the race track quickly took on even greater significance with this new model, the BMW 315/1 achieving its first significant success in the International 1934 Alpine Rally. The starter grid for this rally in Nice was made up of 127 truly outstanding cars looking at daily race sections of 500-600 kilometres to be covered at a minimum speed. On the fourth day there was an additional speed test at Stilfser Joch. After covering precisely 2,867 kilometres or 1,778 miles, 96 of the 127 cars which had originally entered the race reached the finish line in Munich - 66 thereof without having lost one point. The five cars entered by the BMW Works Team were the only cars in their class to complete the International Alpine Trophy without one single penalty point, the BMW 315/1 Team Richard Brenner/Albert Kandl/Ernst v. Delius finishing first in their category. Only 230 units of the BMW 315/1 were completed by mid-1935, many of them going to private drivers. One of them was Ralph Roese, a BMW works driver for many years, who built himself a BMW 315/1 Special. This was a complete re-build of the 315/1, the highly modified engine ultimately developing no less than 136 hp in a brand-new race car body weighing just 380 kg or 838 lb. Given qualities of this kind, it is no surprise that this racing car finished first in its very first race at Nürburgring in 1936, a staggering 17 kilometres ahead of the competition. Understandably, this special model remained a great success over the years until finally winning the German Road Racing Championship in 1939. Achieving this kind of success, both the drivers and the Company soon started looking for more: a car in the prestigious category up to two litres. And so it is no surprise that another, even more powerful version of the BMW Roadster - the 319/1 - entered the market in late 1934. Identical in its looks to the BMW 315/1 with the exception of the air vent on the engine compartment, the BMW 319/1 Roadster was powered by a 1.9-litre tuned to 55 hp and benefiting both from larger displacement and three larger downdraught carburettors. Obviously, an engine like this was easily able to cope with a two-seater weighing just 780 kg, accelerating the roadster in standard trim to a top speed of pproximately 135 km/h or 84 mph. At the same time this was of course a truly exclusive car due to its retail price of 5,800 reichsmarks. Production from 1934-1936 therefore amounted to just 178 units, with the BMW 319/1 again bringing home outstanding success in motorsport. "This information is taken from www.netcarshow.com" |
12-22-2009, 12:53 PM | #6 |
Freude am Fahren
35
Rep 383
And a great group of photos illustrating 75 years of BMW roadster here-
http://www.worldcarfans.com/20905281...-bmw-roadsters Like this one- |
12-22-2009, 01:23 PM | #8 |
Freude am Fahren
35
Rep 383
