BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      11-24-2009, 04:54 AM   #1
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
9" wheel + tire sizing question
Guys, quick question. What's the max tire size I can safely fit on a 9" wheel?
I'm thinking about doing 275/30/19 in the future... just want to see if it's possible.
Also,
Let's say you're running a really high performance tire like an AD08 or RE-11 and a regular performance tire like an Exclaim UHP.
Both are 245f/295r in size.
Would the AD08/RE-11 have less understeer than the UHP just because it's a more grippy tire? Or does understeer/oversteer only affected on sizing.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      11-24-2009, 01:58 PM   #2
Fen335i
Fen335i's Avatar
107
Drives: e92 M3 / X5d / Z4 M Roadster
Good question...I asked a similar question on the forum about 6 months ago in regards to how wide I could go on rear OEM 19's (9.5 rear width)...and I was told a 285 was about as big as I should go...even that was a stretch (literally!).
So for a 9 inch wide wheel, I wouldn't think you would want to go much more than 265. Maybe a 275 would squeeze on there, but it could be pretty tight. Hopefully one of the Tire rack or EAS guys can answer this for you...they would know much better than I.
Also - even if the tire can fit onto the wheel, aren't there some clearance issues up front? Would a 275 fit?
Also,
      11-24-2009, 07:08 PM   #3
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
275 will fit width wise, it's just the sidewall that hits. 255/35 hits the fender liner until you're at about 50% tread.
m3post
