10-14-2009, 01:30 PM | #1 |
Bates '08 Interlagos Launch
126
Rep 1,230
Aftermarket Rim Maths :)
Ok I am starting to over-analyze this stuff and need help.
I've read that the recommended size rims from BMW for winter use is 18x8 ET20 with 235/40-18 tires. However, I have a preference towards handling over snow cutting, so I am choosing a square setup of 245/40-18 which is closer to my OEM 18" widths and I will use the Michelin Pilot Alpin PA3's. I thought about doing staggered, but I like the ability to be able to rotate tires each season to maximize tire life and I think the 245 is close enough to the rear stock size that I wont notice really. So the question is.. if I know what tire I'm buying, and I know I want M6 repo wheels, what SIZE wheels should I get??? I started going crazy with offsets and rim sizes, so I put the data from the four available M6 Repo wheel sizes that made the most sense into Excel: Hopefully my maths are correct!! *(positive # indicates the movment (in millimeters) will be towards the outside of the car, negative # will move the rim in towards the suspension) **(offset calculator: http://www.gtsparkplugs.com/WheelOffsetCalc.html ) It would appear to me that instead of using a 18x8 ET20 as recommended by BMW (which to maintain the rear stance requires a 15mm spacer), I instead should use the 18x8.5 20ET for these reasons:
The only "bad" thing to me is that the rims are the new ones from **********s and I haven't seen anyone using them yet - they are not the Mira branded ones, but a style that **********s rebrands (basically no-name China brand I would guess). I'm sure they are fine/strong/whatever, but just something I'm thinking about. Here is the link to them: http://www.**********s.com/**********s_M6Wheels.html [IMG]http://www.**********s.com/images/Products/**********s%20Wheels/MBM6%20Sil%20E60%2020in%20Sil-GM%201.jpg[/IMG] So, is my logic correct? I am new to wheel/tire sizes but I'm learning!
Custom Exhaust Project: Bates Valvetronic exhaust: http://www.m3post.com/forums/showthread.php?t=253661 -- Exhaust Mod pics in here: http://www.flickr.com/photos/40236795@N03/
DON'T BUY Race Ready Performance electronic cutout valves. Here's why: http://www.m3post.com/forums/showthr...40#post9589740 Last edited by Subw00er; 10-14-2009 at 02:11 PM.. |
10-14-2009, 01:38 PM | #2 |
NASA SpecE30 Racer
82
Rep 1,307
Go with the 18x8.5 +20. They will work great with a 245 wide tire and if the rears being tucked in a little bother you too much go ahead and add the spacer.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com 1987 BMW 325is SpecE30: spece30.ridedomain.com 2009 BMW M3 Coupe: Sold e92.ridedomain.com |
