      10-14-2008, 06:49 AM   #1
MZWIE
388
Drives: M2
Spastic A/C fan
Seems the 1 has the same ailment as the E46's. The fan goes high and low all by itself.
And before you smart alecks say anything...it is not in AUTO....
In the E46 the final stage resistor needed to be replaced. Wonder how long before this is a recall in the 1....
      10-14-2008, 09:14 AM   #2
MZWIE
388
Drives: M2
Why do you move general questions to an area no one ever visits.
I haven't seen this done in other car forums. Now then, if the question was about servicing I would understand.
      10-14-2008, 09:24 AM   #3
ChrisK
ChrisK's Avatar
Drives: '19 M2C
http://www.1addicts.com/forums/showt...ight=fan+speed
This is not new.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      10-14-2008, 05:39 PM   #4
Maine1
Drives: M235xi
I have also experienced the same phenomenon in manual. It's like it is a vehicle speed controlled fan speed - the faster you go the faster it goes. I found it does it mainly with AC off and only the center button on for mid-dash air flow. If I turn on the bottom air along with the middle, the fan speed stays more constant. It does get annoying when it starts taking off on its own.
      10-14-2008, 06:05 PM   #5
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
There was never a recall on any final stage resistor for any BMW. Considering AC neither effects emissions nor vehicle safety, I doubt there will ever be one.
      10-15-2008, 01:49 PM   #6
MZWIE
388
Drives: M2
^^^^ Beg to disagree. I had mine done as part of a recall.
      10-17-2008, 06:01 PM   #7
Mad Dragon
Mad Dragon's Avatar
Drives: 2010 GTI
Like I said...
64 11 06 SI September 2006 Service Action: Install Bracket for Air Conditioning System Pressure Line E92
64 03 06 SI April 2006 Service Action: Recode IHKA Control Module E85
64 06 05 SI August 2005 Service Action: Coding the IHKA E46
64 01 04 SI May 2004 Service Action: Refill Air Conditioning System E53
64 05 95 SI Dec. 1995 Air Conditioning Suction Line (Service Action) E38
64 07 01 SI June 2002 Recall Campaign 01V-206: Engine Auxiliary/Cooling Fan E38, E39, E46, E52, E53
64 13 84 SI November 1984 Recall Campaign 84V-107 Heater Control Valve E30
:wink:
      10-20-2008, 07:33 AM   #8
MZWIE
388
Drives: M2
Whatever. Mine was fixed. There have many unpublicized fixes by BMW. Now to see if they will fix the 1 series.
The A/C controls in this car are the worst I've seen in my last 3 BMW's.
Don't understand why they did not include the temp wheel on the vents. The new 3's have them and they use the same A/C.
Regulating the heat is a pain. Furthermore it doesn't really blow hot unles you set it at 84, at which point it's too damn hot.
      11-22-2008, 08:17 AM   #9
kameleon
Drives:
As someone mentioned above this was and will never be a recall issue.
However bmw has had resistor issues from e36 to now. They look different but certainly fail in the exact same manner.
1addicts
