      08-02-2008, 08:22 PM   #1
timt
Reader, Rare Poster
timt's Avatar
Drives: F80 M3 Black (2015)
Lowering seats
Has anyone come up with a solution to lowering the 135i coupe seats? I opted for the manual sport seats, but even they are a bit too high to wear a helmet while in a comfortable driving position.
Short of throwing out the seats completely for a track seat, has anyone come up with a solution? They feel like they have plenty of room beneath them to be further lowered if a replacement rail system were available. Does such a thing exist or would it require custom fabrication?
Older threads on this topic don't seem to have a result. Sorry if this is the wrong forum but I figured this may be most relevant to track drivers.
~ TimT 2015 M3 F80 Black with DCT and Adaptive Suspension
Previous (all 6MT): Dinan 135i, E46 M3, 2007 Porsche GT3, 2012 Cayman R, 2003 Carrera 4S, 2001 Gemballa Boxster S, and some Audis.
      08-02-2008, 09:36 PM   #2
Lester
295
Drives:
How tall are you? If you adjust the seats to the lowest postion, you should have pleanty of room for a helmet. Is your head that close to the roof liner?
      08-02-2008, 09:49 PM   #3
timt
Reader, Rare Poster
timt's Avatar
I am around 6'2" tall. I have to lean way back even with the manual seats as low as they go. I can "reach" everything, but it is not good to have to reach your arms out so far to get to the shifter or steering wheel and is a real problem in tight turns with fast rotation of the wheel. In short (haha) - it isn't sufficiently low.
      08-03-2008, 02:53 PM   #4
Lester
295
Drives:
I measured my headroom today - with the seat in the low position, I have 4 in. of clearance - at 5'-10". So I guess if you have a tall body, you might be out of room. I don't know what the solution would be - it would seem complex to fabricate new rails, especially adjustable ones.
      08-03-2008, 03:21 PM   #5
timt
Reader, Rare Poster
timt's Avatar
I was hoping that with all the after market seats out there, usually with their own rails (so they don't have to make custom versions for every car) that it would be possible to just get rails from one of those manufacturers and drill accordingly.
The issue you run into in this car as you get taller is that the seats need to be further back so my knees don't slam up on the steering wheel. That then means my arms are too extended to comfortably steer and shift. So as you get taller you also have to get the back of the seat more vertical to be in a good track-driving position. Vertical seating eats up headroom very quickly. I can tool around town leaned back a little, but that is not good for the track.
I may end up just calling one of the shops that installs custom seats to see if I could pay them to fab some rails to work with the existing seats. I don't really need to go 5-point harness and I like my current seats
      08-03-2008, 04:37 PM   #6
spdrcr
Australia
13
Drives: Lotus Elise
Please keep us updated on how you go with this, I'm having the same issue here.
1addicts
