BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
BPM
      04-25-2024, 02:40 AM   #1
Alexei9012
Alexei9012's Avatar
Australia
Drives: BMW M3 E92
Exclamation M3 E92 harsh vibration and clunking:Help
Hi guys, I just got my engine and transmission mounts changed to stiffer ones, didnt have any problems or noises with the car before hand. Now when I accelerate between 2000-4000rpm the car has a harsh vibration in the rear and there is a random clunking when I slow down. Think it’s the centre support bearing but not 100% sure. Can anyone help?
      04-25-2024, 05:14 AM   #2
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
solid transmission mounts create vibrations in that range, what mounts did you install?
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged
First DCT to Manual Conversion Worldwide
KW CS, BBS RI-A, BW Headers, Snow 2.5
      04-25-2024, 06:39 AM   #3
M3SQRD
M3SQRD's Avatar
2383
Drives: E92 M3,G20 330ix,F22 240iX,F82
I agree. The vibration and clunk you hear are due to stiffer transmission mounts.
      04-25-2024, 06:46 AM   #4
Alexei9012
Alexei9012's Avatar
Australia
Drives: BMW M3 E92
I put 034 Motorsport density line mounts in, not as hard as Polly or solid but harder than stock
      04-25-2024, 07:05 AM   #5
BimmerMan33
BimmerMan33's Avatar
Drives: 2011 BMW M3, 2014 BMW X5
Any aftermarket solid rubber engine/transmission mounts on this car always bring out significant vibrations at multiple rpm ranges..
There is a reason why BMW went with liquid filled engine mounts.. liquid absorbs vibrations.. BMW could’ve saved money by going with soft solid rubber but wouldn’t get the desired refinement!
Based on personal experience with Bimmerworld rubber motor mounts, the vibrations do decrease after 1200 miles or so of use but still present. You might want to keep driving for a thousand miles & see if it improves enough..
      04-25-2024, 07:16 AM   #6
Alexei9012
Alexei9012's Avatar
Australia
Drives: BMW M3 E92
Alright thank you, I’ll keep doing that already at 300ish miles, if not I’ll switch back to OEM 😂
      04-25-2024, 09:33 PM   #7
krudmunk
Drives: F80 M3
I experienced some vibration immediately after 034 transmission mounts as well. Pretty normal.
After a while they get broken in and feels better and reduce a bit. OEM transmission mounts feel bit sloppy when shifting in a manual.
There is still a slight vibration but shifting feels much crisper and cleaner in a manual now. I gotten used to the minor vibratoon as there are more benefits to it.
      04-27-2024, 12:08 AM   #8
Alexei9012
Alexei9012's Avatar
Australia
Drives: BMW M3 E92
Update: I started driving today and the vibrations and noises are gone. I assume the new mounts just broke in finally 😅thank you all for you help!
m3post
