03-17-2024, 10:07 AM | #1 |
7609
Rep 3,608
DCT Clutch Slipping
Ran into some unnerving clutch slippage at the track today. So in order of what happened today:
1. Under WOT there were moments where the clutch would slip in gear, revs would shoot up, I would then reduce throttle slightly and the clutch would re-engage as if nothing happened. This would happen mainly on sustained WOT, so not when I rolled into WOT coming out of corners. 2. At one point later in the day the car was quite hot, on a fast lap the car just popped into neutral instead of up shifting to 5th. It would not go back into gear while rolling, so coasted the car back to the pits in neutral. Once in the pits, the car was shut off and restarted - the engine was misfiring and sounded rough. It was then turned off and started again and everything was back to normal. Car was also low on gas so fuel cut may have been a factor in this instance. The only major thing that I did prior to this track day was tapping in my AIM solo 2 dl into then CANBUS. Anyone else encountered this issue on any F8X? Im thinking at the least it’s a transmission flush and adaptation reset or potentially replacing the clutches. The car is only at 28k miles and always been at stock power. It is heavily tracked though (10+ days a year).
Current: F80
Prior: F82, F32 |
03-17-2024, 11:13 AM | #2 | |
Rep 1,322
If it happens despite that, then I guess time to start replacing stuff... |
RugbyBro7609.00 |
03-17-2024, 05:19 PM | #3 |
Rep 960
I say flush, new filter and add a larger DCT pan either from Seems Legit Garage, Burger, Vargas or IND/Fall Line are all good options. This will help you manage temps, sounds like you've degraded the DCT oil and should have been replaced due to your high track usage. Try that first then add a DCT cooler from CSF or Mishimoto, as they are two pass design.
The price we have to pay, good luck man. Keeps us posted on your findings.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
RugbyBro7609.00 |
03-18-2024, 11:03 AM | #4 |
7609
Rep 3,608
Plan of attack right now is:
1. Transmission fluid flush 2. Bimmerworld dry-break / overfill kit 3. Trans tuning to increase clamp force - either OE GTS or XHP Wanted_M do you know much about the XHP trans software - I saw you posting in the XHP thread. Mainly wondering if the extra tunability is worth it over the GTS flash.
Current: F80
Prior: F82, F32 |
Wanted_M772.50 |
03-18-2024, 11:18 AM | #5 | |
Rep 1,322
Helpful tidbit: screw the blue banjo fitting and black extender/coupler piece together first before fitting it to the trans |
RugbyBro7609.00 |
03-18-2024, 11:50 AM | #6 | |
7609
Rep 3,608
Current: F80
Prior: F82, F32 |
03-18-2024, 11:56 AM | #7 |
Rep 1,322
Yeah, my suspension self definitely hears you bigtime on that one (), but for this if it were me I'd definitely wait to see if the easy stuff works first. Your mileage is so low (like mine).
03-18-2024, 02:42 PM | #8 | |
Rep 960
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf Last edited by Wanted_M; 03-18-2024 at 02:48 PM.. |
03-21-2024, 11:53 AM | #10 |
///M Powered for Life
11510
Rep 10,341
At the track, eventually you can run into DCT issues, and depending on what you mean by "heavily tracked", it will require more work in the future. Fortunately it's a rare occurrence and most people will never experience it due to pace.
The engine running rough throws me off a bit, no DCT error should cause the engine to run rough. I'm surprised it even audibly slips, the ECU should cut power when it senses any slip at all. Stage 1: Cheap solutions: Put new fluid in. If you are using OEM and switch to Redline, it needs a full flush (or two normal changes) to get the old fluid out. BW has a thermostat bypass BW has an overfill kit Stage 2: Less cheap solutions: The Slon DCT pan. Unlike the other ones discussed, it has more baffling and adds a spacer to lower the suction point. To have a bigger pan but to suck from the top will still allow the DCT to oil-starve. XHP software, which clamps more than the GTS software Bigger DCT cooler There's more, but every time it gets more expensive! |
03-21-2024, 12:01 PM | #11 | |
Rep 1,322
04-03-2024, 10:58 AM | #13 |
Rep 940
What tune/Power level are you at? Did you get any DCT temp warnings, I think its about 250F.
I was getting over temp warnings my last event of last year. I pulled the DCT cooler out and replaced it with a CSF one. The old one was pretty beat up, but more importantly there was a lot of highway trash and leaves behind the dct cooler prohibiting flow. I already had the overfill kit, its pretty neat. How old was your fluid?
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
