02-29-2024, 03:35 PM | #1 |
Rep 16
Valvetronic motor issue
I recently replaced my Valvetronic motor because of that awful ticking sound. But now it’s saying the faults are too frequent and it’s deactivated the system! Did I so something wrong In my steps to replace this?
02-29-2024, 09:10 PM | #4 |
Rep 16
Also is there any specific way to remove it and install it. I took out the minimum stop sent the shaft back and just pulled out motor and put new one in and then everything back together?
03-01-2024, 03:12 AM | #5 |
Rep 112
I recently did this. ISTA coding is required to set limitations. It cycles the valvetronic motor 500 times during the reset. Took several minutes to complete and it was interesting seeing how the valvetronic motor works with the car at idle.
Prodigal M3nace1.50 Jbonly211104.00 |
03-01-2024, 03:29 AM | #7 |
Rep 112
“Easily” is a subjective term! Requires a lot of storage space and a license. I’m sure you can find a free version somewhere with some digging but I purchased the license when I got the software.
Prodigal M3nace1.50 |
03-01-2024, 03:51 AM | #9 |
Rep 112
Hopefully it did not cause any damages! I would not drive the car until you do the ISTA coding as the escentric shaft would set you back at least $2k if it’s damaged
03-01-2024, 03:58 AM | #11 |
Rep 112
03-01-2024, 09:29 AM | #13 |
Rep 112
Look in the “DIY and Coding” sub forums
03-02-2024, 08:48 PM | #14 |
Rep 16
This is what it’s giving me not allowing a relearn. I’m going to pull it all out again. The new motor was a little stiff during instal.
So I’m going to try it all again |
03-03-2024, 06:50 PM | #17 |
Rep 16
None. but there is significant resistance compared to old motor. should the spring back be able to move the motor?
Also I cleared dme and tried resetting and it got through 10 cycles and then said it failed and the dme code came back on again Also one thing to note I bought one of those cheaper motors for $125 I think next bet is to buy a oem from FCP EURO. And pull this apart for third time. Because my last motor was going because it worked sometimes and sometimes it didn’t. |
03-03-2024, 07:17 PM | #20 | |
Rep 112
