01-23-2024, 03:02 PM | #1 |
Rep 1,401
Turbo comparison S55 vs S58
I had the opportunity to disassemble s58 turbos, and I decided to take some pics to compare it with s55, I hope you like it.
Compressor housing Exhaust housing CHRA Shaft & Wheels Size of the wheels, both compressor wheels are billet. S55 Compressor wheel Inducer 40mm Exducer 51mm Turbine wheel Inducer 42.5mm Exducer 37mm S58 Compressor wheel Inducer 45mm Exducer 56mm Turbine wheel Inducer 47mm Exducer 41mm It's a shame that the s58 turbos don't fit on s55 otherwise it would already have them installed on my car with a small mod on the wheels Last edited by Track/S; 01-24-2024 at 12:26 AM.. |
13
theweebabySeamus383.50 W///7529.00 SYT_Shadow11509.50 jlcolon200124.50 McBobby Jr212.00 astris624.50 ra2289308.50 D_SheerDrivingPleasure1104.50 chetrickerman10446.50 fivaxis51.00 sly1types431.50 M_Torx345.50 HomoPirate84.00 |
01-23-2024, 03:53 PM | #3 | |
Rep 1,401
Everything about the s58 turbos is wonderful, I love them, the first time I fall in love with turbos I will weigh them tomorrow, but there is a big difference, the wheels of the s55 are small. |
SYT_Shadow11509.50 |
01-23-2024, 04:18 PM | #4 |
Rep 961
Nice comparison, the upgrades are abounded. Our wheels are small, and you can see the compressor/turbine AR are much larger. The manifold design is way better. Now we know why the G80/82 can push 700+ whp.
Can we adapt the turbo mani/housing!!
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
01-23-2024, 04:19 PM | #5 | |
///M Powered for Life
11510
Rep 10,342
It would be really interesting to see a comparison of S55, S58 and then a few aftermarket options in terms of weight |
M_Torx345.50 |
01-23-2024, 10:01 PM | #6 | |
2461
Rep 5,918
The s58 turbos are beautiful compared to the s55 turbos. |
Track/S1480.50 |
01-23-2024, 11:14 PM | #7 |
212
Rep 577
The manifold port size delta is interesting. It’s cool to see these turbos side by side so props to you.
current
'18 F22 240i xDrive - FBO '16 F82 M4 ZCP - FBO previous '08 E90 335i Montego Blue |
01-24-2024, 12:38 AM | #8 | |
Rep 1,401
Later I will upload more pics with the modifications of each one. |
SYT_Shadow11509.50 Wanted_M772.50 |
01-24-2024, 09:16 AM | #9 |
Rep 55
Good comparison shots and cool the S58 is MHI.
The OE S55 "base" setup is no slouch and has some good potential for upgrades. I'd say our S55 Stage 2 based offering still has a bit of a nudge on the OE S58 setup. The S58 already being a TD04L is great but it is hard to see what kind of material is available for a larger turbine, especially around the diffuser/tip height areas. The problem with the S55 turbine housings is there is no significant material available beyond where we are currently at with our Stage 2 setups custom turbine (a bit larger than TD04L). So if you want a properly fitted larger wheel you really need to start drastically increasing the tip height of the turbine, which unfortunately means you end up with a terribly responding turbo. Hopefully for the S58 crowd that is less of an limiting issue inherent to the castings, because while the S58's TD04L(R in this case) is a great start it definitely is a limiting factor for large power. All in all the OE S58 setup is a great base setup and should have even better room for growth, they appear to be a very good start to a very potent set of bolt-on upgraded turbos. Last edited by Rob@RB; 01-24-2024 at 09:23 AM.. |
01-24-2024, 09:28 AM | #10 | |
ECUTek Master Tuner
10447
Rep 1,735
Drives: F80 M3 YMB
What a difference in the port diameter and the turbine housing A/R! This is great information, thank you for sharing
sly1types431.50 |
01-24-2024, 11:31 AM | #11 |
24465
Rep 191,414
Thank you for sharing; the S58 is a significant upgrade over the S55. ]
Im glad BMW made a big change in this area.
01-24-2024, 11:50 AM | #12 |
Rep 716
Very interesting to see, thanks for sharing!
Tough to tell from pics, but the s58 manilfold appears to more directly route the pulse energy into the turbine housing than the s55 manifold. Probably helps mitigate any spool loss or responsiveness loss due to the increase in wheel size. |
01-24-2024, 01:04 PM | #13 | |||
Rep 1,401
Yah, the shape is more direct without closed curvatures PD: S55 upgrade version vs S88 upgrade version S55 Mod compressor wheel Inducer 44mm Exducer 56mm Mod turbine wheel Inducer 49mm Exducer 44mm S58 Mod compressor wheel Inducer 49mm Exducer 63mm Mod turbine wheel Inducer 53mm Exducer 48mm |
chetrickerman10446.50 M_Torx345.50 |
01-24-2024, 02:08 PM | #14 | |
Rep 55
Overall I am with you on the fact that there is a point where you cant just keep cramming larger wheels into housings that are tapped out, while many seem to just keep at it for that snapshot in time dyno chart the performance and reliability will suffer. This is why I probably will leave well enough alone with the S55 units, leaving an offering that is very tastefully designed and to give a much larger power potential over OE. Beyond that point some full custom setup would be the recommendation, or some other vendor that one feels comfortable with using. On the other hand the S58 units appear to be quite awesome in OE form and based on your new specs should be some serious units, with a base housing foundation that could very likely accommodate it well. I have had some larger MHI TD04 reverse turbines for a long time now, was going to use for the N20 but would be nice if they could be purposed into these S58 housings someday. Good luck with this upgrade venture and thanks for sharing. |
Track/S1480.50 |
01-24-2024, 02:33 PM | #15 |
11510
Rep 10,342
if only we could find TiAl wheels that are reverse scroll!
01-24-2024, 02:52 PM | #16 | |
Rep 1,401
Yes, it would be hell
I have used several measurements on s55 and the one I like the most is 44mm. Last edited by Track/S; 01-24-2024 at 03:07 PM.. |
01-24-2024, 04:48 PM | #17 |
Rep 55
An overly big Inducer is the main concern, then it ends up hanging wide out into the volute exhaust flow due to housing design. If one is using a 45.5mm exducer that would mean they more than likely have a 50.5+mm inducer. While they may make good power and flow more they likely fail well more often along with it, thus it is a huge push and a risk not worth taking IMO. I've seen some vendors mass produce literally hundreds upon hundreds of these types of builds that flop and are essentially worthless boat anchors in very short order. A very large tip height can help null this issue a bit, but these S55 housings are not too forgiving about it. Hopefully the S58 housings have more potential.
03-01-2024, 12:32 PM | #18 |
Rep 24
D_SheerDrivingPleasure1104.50 M_Torx345.50 |
03-01-2024, 01:01 PM | #19 | |
Rep 1,401
M_Torx345.50 |
03-01-2024, 05:34 PM | #20 | |
Rep 927
Wow. For ahich tractor class do you build? As a young boy I attended a tractor pull at a local Ag center. It was thrilling to see the crowd erupt in cheers at a full pull. Motorsports at it's finest. |
M_Torx345.50 |
03-02-2024, 01:48 PM | #21 |
Rep 5
03-02-2024, 03:25 PM | #22 |
11510
Rep 10,342
Very interesting, thank you!
