01-09-2024, 02:30 PM | #1 |
Rep 2
2010 z4
I just purchased a 2010 z4 30i but received no user manual and am trying to learn the car without it.
My main issue is I can't connect to the radio by bluetooth. I've read several posts that tell you how, but i don't have the phone icon on my radio as an option. I only have "comp" and "config" I do have the steering buttons for the phone. Any help would be appreciated. |
01-09-2024, 02:45 PM | #2 |
Rep 621
Drives: E89 Atacama Yellow 35is
You can download the correct manual from bmw in their owners manual app..if you put the vin number in…
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0 Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886 |
01-09-2024, 03:10 PM | #3 |
852
Rep 4,058
I posted it on the E85 page but here it is again - hope it helps!
https://www.manualpdf.in/bmw/z4-2010/manual |
01-09-2024, 05:00 PM | #4 |
153
Rep 512
If it doesn't come up as an option on the headunit then you don't have Bluetooth.
All radio front panels are the same (standard radio, not iDrive) and all multifunction steering wheels have the same buttons no matter what is spec'd from the factory. Assuming you have the standard radio, this is the radio manual... https://www.dropbox.com/scl/fi/r09bd...d7sdoiqhj&dl=0 And incase you do have Bluetooth, here is the standard radio Bluetooth manual... https://www.dropbox.com/s/arblpchc6l...phone.pdf?dl=0 Hope that helps. If you do have iDrive, I have links for that as well if you need it.
Dave
2011, E89 23i, Grey with Red leather.... relatively basic (getting less and less basic with every new retrofit)! My Z4 E89 YouTube channel... https://www.youtube.com/channel/UCtt...0vHFUQnoEvKB2Q Last edited by DavesZed; 01-10-2024 at 06:24 AM.. |
01-10-2024, 03:22 AM | #6 |
159
Rep 472
Earlier e89 z4-s did not come with bluetooth audio, and only had bluetooth for phone functionality...
If i remember correctly at some point in 2010 bluetooth got a module update that gave bluetooth audio functionality. Something about combox module i think... So there is a chance that your car is early 2010 build or even 2009 build but registered in 2010 and doesnt have that update. I have a 09 35i and realization that it doesnt have bluetooth audio was the biggest dissappointment i had after buying mine. Did not know about that before buying it. So i still use aux in cable with lightning adaptor to hook up my iphone.
2009 35i DCT Havana brown with ivory white interior. Mods: Cobb stage 1+FMIC, Wagner EVO1 FMIC, BMS DCI, KW V3 suspension, M3 front control arms, Hardrace RTAB, Michelin Pilot Sport 4S tires.
01-10-2024, 10:48 AM | #7 | |
Rep 71
2009 BMW Z4 35i
2009 Infiniti EX35 Journey AWD 2017 Lincoln MKC AWD |
01-21-2024, 03:46 AM | #8 | |
11
Rep 23
