01-04-2024, 01:19 PM | #1 |
461
Rep 2,089
Drives: 2017 F80 M3 ZCP BSM 2012 E82 1
WTF is happening here?
White oil? wtf is going on w this?
2017 F80 ZCP BSM - Klein Innovation. ActiveAutowerkes. AR Design. BootMod3 Paul Johnson. EvRw. Project Gamma. RW Carbon. UCP. UUC. Hawk. Dinan. NGK. Macht Schnell. TMS. VR. aFe.
RIP - E82 135i - 7/7/2021 |
01-04-2024, 01:35 PM | #3 |
2458
Rep 5,916
Also, in addition to short trips, has it been cold and damp? Likely moisture and/or condensation build up due to short trips and damp conditions. Worst case would be blown head gasket but you’d have plenty of other symptoms concurrent with white residue. Do you have any other symptoms and/or issues?
NORAGRETS460.50 |
01-04-2024, 01:37 PM | #4 | |
461
Rep 2,089
Yes I live in Boston and temps just got into the 20’s so that makes sense
01-04-2024, 10:07 PM | #5 |
Rep 960
Personally, I'd change oil and filter as emulsification is no bueno for the engine/bearings and you can't tell what the sump looks like due to missing a dipstick. Has the car been sitting for a while? I encountered something similar years ago and found to have a worn gasket for oil cap as moisture was accumulating there causing what you see there.
What oil weight are you using?
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
01-04-2024, 10:13 PM | #6 | |
461
Rep 2,089
Oil and filter were literally just changed like 200 miles ago. I did puncture and replace my oil cooler about 1000 miles ago and had to fill up with Mobil 0W30 (euro spec) bc my body shop ordered 0W20 and I didn’t wanna wait for them to order the right stuff. Only ran that for 1000 miles tho. I did notice the white discharge/whatever when I changed back to BMW LL-01 0W30 (again 200 miles ago). 0W30 which may need to be changed to 5W30 since it’s getting quite chilly here. That may be my issue?
01-04-2024, 10:53 PM | #7 |
Rep 960
0W-30 is good for winter, 0W-20 is too thin for my liking on these engines. For summer run a 5W-40. Maybe inspect the oil filter and see if there anything in there, look for that milky white residue. Change gasket on oil cap or get a new one and go from there. Good luck man, hope that solves your issue.
M4CS Frozen Blue
NORAGRETS460.50 |
01-04-2024, 10:55 PM | #8 | |
461
Rep 2,089
Wanted_M772.50 |
01-04-2024, 10:59 PM | #9 | |
461
Rep 2,089
01-05-2024, 01:14 PM | #10 |
Rep 46
When I bought my used f80 last year, it had some milky residue too.
The car sat 2 months unsold until I bought it, so I hoped it was just that. I cleaned it, did an oil change and haven't had it reoccur. I also check my coolant levels every 1-2 months. |
NORAGRETS460.50 |
01-05-2024, 06:34 PM | #11 |
Rep 1,011
Its condensation and totally normal for cars that dont get driven long enough to operating temps. If you drive the car long enough, it will go away. Its not sludge which is a much bigger problem.
If you only do 10-15 min trips, you might want to consider an electric car. |
Track/S1480.50 |
01-06-2024, 11:53 AM | #12 | |
461
Rep 2,089
I do a lot of city driving but I also do a lot of longer trips. Typically I’m on the road for work 3 days a week so it does get driven. That’s why I got the damn thing in the first place. I drive 300-400 miles a week for work and I wanted a car I loved driving.
01-06-2024, 04:08 PM | #13 | |
Rep 1,011
I wouldnt worry about it unless it builds up more. You can also do a used oil analysis if you are concerned. |
NORAGRETS460.50 |
01-06-2024, 05:09 PM | #14 |
Rep 650
I’ve fallen into a bad habit of doing short trips to work where sometimes I need the car afterwards.
I’m due to change oil and filter soon. Any other tips or things I should look out for? |
01-06-2024, 08:35 PM | #15 |
461
Rep 2,089
That’s fucked
01-08-2024, 02:00 AM | #16 |
Rep 650
I checked mine after I got back in to it
It had been parked up in a cold under ground car park over Xmas for two weeks. I’m due to change oil soon(it was changed 10k km ago) Any other advice on this? Thanks. |
01-09-2024, 11:19 AM | #17 |
Rep 1,011
Oil looks normal and if you are at oil change interval, do it. It does look like maybe your oil cap is bad? It shouldnt be sweating oil like that or maybe no one has ever cleaned it lol. Clean it up and reinspect again.
jaylazy2020267.00 |
01-09-2024, 11:27 AM | #18 |
2458
Rep 5,916
Unless I’m missing something, the oil on this cap looks normal for an oil about to be changed. Oil cap looks like it’s leaking and accumulating debris around the cap. Clean the cap, reinstall and then check for leaks/debris. New cap if it collects debris again. Leaking oil caps is a common issue on the s65.
01-09-2024, 05:27 PM | #19 | |
Rep 650
I was most concerned about seeing any yellow gunk and hadn’t realised that it may need a new cap which I’ll order tomorrow and see how it performs Thanks for the info. |
01-11-2024, 01:47 AM | #21 |
Rep 650
Update after drive to work this morning.
Noticeable amount of yellow was on the new cap and even more on the flange where it connects as per picture. Another observation was the smoke/vapour rising out once I took off the oil cap Is that normal? Cheers |
