12-13-2023, 07:00 PM | #1 |
591
Rep 469
Turbo exhaust turbine discoloration
Is this green color a normal discoloration or indicative of something abnormal? 33k miles and 20ish track days on these stock turbos.
12-13-2023, 07:19 PM | #2 |
Rep 178
that’s the first time i’ve seen this. have you had any loss of performance or it’s just the color you’ve seen change
2015 Liberty Walk M4
F80Paul Tuned New Jersey |
12-13-2023, 07:30 PM | #3 |
Rep 55
Use any fuel additives, octane boosters, etc? Never have seen green but usually orange/red'ish with octane boost. Coolant can be green but you'd probably know if you had an issue there. Definitely odd but in for the answer.
12-14-2023, 08:18 AM | #6 |
591
Rep 469
I had 2 spark plugs ceramic separate so replaced those and injectors. Since it's winter I decided to pull these off and check them and do some preventative maintenance.
12-14-2023, 08:20 AM | #7 |
591
Rep 469
12-14-2023, 08:25 AM | #8 |
591
Rep 469
12-14-2023, 08:39 AM | #9 |
Rep 1,401
12-14-2023, 08:58 AM | #10 |
Rep 55
As mentioned above the TMIC leaking seems to be the most plausible, I'd definitely keep an eye on that fluid level. The blue coolant could be morphing into this blue/green look among with general combustion turbine discolorations.
12-14-2023, 09:36 AM | #11 |
Rep 1,401
The low pressure part does not enter the intake, I think this is what it refers to, i guess it was leaking outside.
