04-07-2023, 10:26 AM | #1 |
Rep 12
changing the springs on f80 m3
questions?
do i need the special tool suspension strut tool (18mm/12PT) with the 1/2 drive? i do have an impact to spin the 18mm strut bolt out so that i can drop the entire strut. thanks |
04-07-2023, 10:39 PM | #2 |
Rep 3
It would be best to use for proper torqueing of the top nut. I would suggest using one ,for piece of mind, as it is a relatively inexpensive tool.
If you do not have passthrough sockets for the end link, may want to look at picking some of those up as well. I am not suggesting this but you could probably get away with just sending it with the impact as well. Same way you could do this for the front endlink without using a passthrough socket and allen. |
04-11-2023, 01:24 PM | #3 |
Rep 326
I changed the front springs myself on my wife's F80 without taking out the whole strut assemblies. I would suggest getting the Schwaben 18mm strut nut socket for the thorough job of properly torquing the strut bolts.
04-11-2023, 01:41 PM | #4 |
I'm Batman!
3949
Rep 1,477
I used one of these, don't know why I can't find the Schwaben one on Amazon where I got mine from a few years ago, but any socket of this style will do, just make sure it's 18mm
https://www.amazon.com/ZKTOOL-PORSCH...f_=as_li_ss_tl
S55, 2JZ, M48.00 |
