03-21-2023, 08:32 PM | #1 |
1470
Rep 1,637
Paint defect. Bubbling and rusting?
Hi guys
Last week, I noticed my friend’s have tiny paint bubble near fuel filler housing. After inspection by lifting rubber lip a bit, there are few small groups of tiny bubbles along lower edge, bubbles look like first pic (all of the pics not mine, took it from internet) One of them shows small rust. The car was purchased new 8 years ago and never repainted the area. He took it in under corrosion warranty and panel has to be repainted which he does’t like it. SA told him that one of his client’s F82 had similar issue (my friend’s is F32) Have no idea if bubbles are new or had it there first place but never spread. Other options to fix this without repaint large area? Any rust repair product you guys suggest? Thinking about sanding and touch up. Thank you in advance. |
03-22-2023, 05:50 PM | #2 |
Rep 138
Sorry to hear about the rust under the paint bubbles. I hate to say it, but I have never found any rust “fixes” better than what a body shop would do prior to respray. The rustoleom stuff is just a bandaid and you will be forever facing more rust from the same spot. At least that was my experience with an old VW I had. Once the metal is rusted all corrosion resistance is gone and it will keep coming back
I personally can’t see rust, is it possible it’s just clear coat failure? If so a light sanding and touchup could be ok since it’s relatively hidden. Others may have options, it’s possible I waited too long before trying to fix my VW. P.S. There is a hole in the fuel cap door you can insert the cap in so it doesn’t rest on the paint. |
Nomana1470.00 |
03-23-2023, 12:20 PM | #3 | |
1470
Rep 1,637
FYI the pictures are not from the actual car, just reference I took from online. |
03-23-2023, 01:00 PM | #4 |
Rep 138
