01-05-2023, 01:21 PM | #1 |
Rep 92
help me identify this noise please
Hello guys, posting in the wrong forum because i guess someone here in might have a solution. My car is a M6 GC
One video is driving and decelerating And other two are standstill revs holding it at 1000-1200 rpm. Is this the wastegate rattle or heatshield? Car has vrsf catless downpipes along with akrapovic exhaust. The standstill rattling has started since a few days and everytime i drive around cruising it sounds like a bag of nails. It’s super embarrassing. Anyone in here? Video link - https://youtube.com/shorts/U1ecv8oAcy4?feature=share https://youtube.com/shorts/pMpEyrcLoNA?feature=share https://youtube.com/shorts/6lDgDM6IvVY?feature=share Incase anyone is not able to view from the link here the videos are named ‘Wastegate rattle m6’ ‘heatshield or wastegate?’ ‘Wastegate rattle’ on YouTube. Looking for advice. Thanks in advance. |
01-05-2023, 05:55 PM | #2 |
5505
Rep 5,184
Damn that sucks. To me I t sounds like something broke loose inside your exhaust, not wastegates. Have a buddy listen (sorry for his ears, you owe 2 beers) to identify if this is under hood, middle of car, or rear section. Then if you have no jack, drive 2 tires up a driveway onto the curb to lift one side up (the side with exhaust). Now after letting things cool you can wiggle under the car and thump around with a fist to find the rattle.
'18 F80 Base 6MT | '19 F82 Exec DCT | '18 F82 Comp Exec DCT | '23 G80cx
01-05-2023, 11:52 PM | #3 | |
Rep 92
01-06-2023, 07:42 AM | #5 |
5505
Rep 5,184
Do your downpipes have flex sections? If yes, look there first. Otherwise you need to check your brackets. The heat shields usually don't come loose all of a sudden.
Danishp9722.50 |
01-06-2023, 08:35 AM | #6 |
Rep 92
No idea as i got the car preowned with all the mods done. Not sure if vrsf catless pipes have flex sections
01-06-2023, 10:31 AM | #7 |
Rep 696
Drives: 2015 f80 M3
Just throwing darts here. I need to listen with headphones.
I looked up the dp's, and they do not have a flex section. But do have a rather large slip fitting. The noise does seem rpm dependant, so that would lead me to think wastegate (I have the S55 one at 2k). I also leam that way as the catless dp's I woul think would amplify any wastegate/turbo rattles. Your turbos sit in the middle of the top of the motor (hot turbo set up) so the wategates should be eaisly accessable. I agree with TJ that heat shields just coming loose seems odd, but I am not familair with the shield arramgent in your car, so possibly there is a piece that rattles at the right frequency. It reminds me of Subaru days and the rediculous rattles you would get from the varios cheap shileding. I would start under the hood and follow the dp's from top to bottom to see if whomever istalled these things made sure eveything was clear. As TJ said, if you have the ability spend some time with friends poking around the car do so. Do you have access to a lift? or at least a way to jack it up and get under the engine area? If not, as others said, take it to the dealer or reputable indy and let them poke around. Also, don't be embarrased. I can think of a million other things to be embarrassed about. You are driving an M6. Most won't notice the noise... Good luck and keep us posted! josh |
01-06-2023, 10:35 AM | #8 | |
Rep 92
spidy512502.00 |
01-06-2023, 10:52 AM | #9 | |
Rep 92
Just a doubt. People on youtube and other Facebook forums have fixed the wastegate rattle by tightening the arm or by fixing a spring on the arm to create tension, would that spoil the functioning of turbo in any way? Also if this noise is ignored, will it spoil the turbos? |
01-06-2023, 11:04 AM | #10 | |
Rep 696
Drives: 2015 f80 M3
With that said, I think many of those fixes should work fine, as along as they do not impede the wastegate actuation. My only concern (and why I have not bothered to fix) is I do not want to create a potential issue by introduscing a fix that has the potential to create too much of a restriction on the wastegate actuation. That can lead to bad things motor wise. As far as letting it go, no I don't think it will cause issues. I am of the belief that the rattle from our turbos is a "feature" less of an actually issue. But for some the noise is unbearable, so off you go to fix it. This is of course subjective. in the meantime, enjoh the car and lean on others locally to help you narrow it down. Let us know what you find. josh |
01-06-2023, 11:09 AM | #11 | |
Rep 92
01-08-2023, 09:07 AM | #12 | |
Rep 92
01-08-2023, 09:48 AM | #13 |
5505
Rep 5,184
Pull off your intakes and CP (rags in holes) to make hand room and then check the wastegate arms for play. If they're loose you've a place to start investigating, and if they're tight you've ruled it out (mostly). You can also thump on the heat shields to see if the rattle is there.
spidy512502.00 |
01-08-2023, 10:52 AM | #14 | |
Rep 696
Drives: 2015 f80 M3
At this point I think you need to get the car in the air or on a lift. Have a buddy push the gas pedal while your under the car, etc. We can keep guessing, but being able to pinpoint the location should be the focus. Forgot to ask, have you popped the hood and gassed it? If so does it allow you to hear it any better? I am going for a drive in mine later, I will pay more attention tot the rattle.... josh |
Danishp9722.50 |
01-09-2023, 02:24 AM | #15 | |
Rep 92
spidy512502.00 |
